Geant4 Installation with Conda
I am trying to install Geant4 with conda on a Linux virtual machine ran with an ARM macOS. After downloading conda I tries running the following commands:
conda config --add channels conda-forge
conda config --set channel_priority strict
conda install geant4
Then I got this error:
~$ conda install geant4
Channels:
 - conda-forge
 - defaults
Platform: linux-aarch64
Collecting package metadata (repodata.json): done
Solving environment: failed
PackagesNotFoundError: The following packages are not available from current channels:
  - geant4
Current channels:
  - https://conda.anaconda.org/conda-forge
  - https://repo.anaconda.com/pkgs/main
  - https://repo.anaconda.com/pkgs/r
To search for alternate channels that may provide the conda package you're
looking for, navigate to
    https://anaconda.org
and use the search bar at the top of the page.
I tried running other commands such as:
$ conda create -c conda-forge --name <my-environment> geant4
$ conda activate <my-environment>
Which is what I found on the officiela Geant4 website but always got the same error. Is geant4 no longer supported with conda? I did find geant4 in anaconda.org here:
Geant4 | Anaconda.org
and ran the following commands
conda install conda-forge::geant4
conda install conda-forge/label/cf202003::geant4
But still got the same error.
I’d appreciate it if someone knows how to move forward from here. Thank you.
Khalil
