Geant4 on windows, Nistmanager not working?
Geant4 Version: 11-03-01
Operating System: Windows 10
Compiler/Version: VS2022
CMake Version: 4
I have installed Geant4 on a windows10 computer using VS 2022, QT6 (shouldn’t matter for this issue). I have run geant4.bat, and even manually set the environment variables (for running .exe from file explorer).
I have a base application I have used that compiles fine on Mac and Linux, but when I run it I get the warning that the Nistmanager->FindOrBuildMaterial material <> is not found. Looking in the source code, it seems this should return whatever G4string I passed to FindOrBuildMaterial().
In my code I have nman->FindOrBuildMaterial(“G4_N”);
I have tried first creating a G4String name = “G4_N” and get the same issue.
What could be causing my nistmanager to initialize, and run its function, but not get the string I pass to it?
Could you post your code or a minimum reproducible example of the problem please?
