I have a Geant4 program simulating hadrons incident a shashlik calorimeter. I found that the program might break down “randomly”. Sometimes it could finish 10000 events, while sometime it will break down after several hundred of examples.
I tried setting the verbose level of run to 2 and the verbose level of physics to 1.The output infomation was still just “Segmentation fault”.
_Geant4 Version:_10.7.p03
_Operating System:_ubuntu20.04
Could you provide more information on your output ? There is a debug mode to help find less visible issues : https://geant4-forum.web.cern.ch/t/error-segmentation-fault-core-dump/10918/2
Happy coding !
Thank you.
I am tring to run in debug mode. But I don’t know when the program will break down. It could happen in several hours or several days.
I will update the infomation when it happens.
There is still not too much infomation.
G4WT15 > --> Event 600 starts with initial seeds (29272636,61172798).
G4WT31 > --> Event 900 starts with initial seeds (39147869,16921800).
Thread 27 "LSShashlik" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff957fa700 (LWP 3982584)]
0x00007ffff577fad7 in G4TouchableHistory::GetVolume(int) const ()
from /home/llm/software/geant4/install/lib/libG4digits_hits.so
(gdb)
Indeed, I encountered a “Segmentation fault” some time ago and was able to identify with the debug mode. Perhaps someone more knowledgeable might be able to see the source of the issue.
Have a nice day.
Hi @Linmao_Li
Thank you for your post.
To help identifying such rare events, there a procedure one can follow:
- Enable saving the seed used to initialize the random engine at the begining of each event. To do so, you can use the following UI command:
/random/setSavingFlag true
- If a segmentation fault occurs, identify the
.rndm file
- Restart the simulation with the
.rndm file using the following UI commands:
/random/resetEngineFrom currentRun.rndm
/run/beamOn 1
I hope this helps to find the segmentation fault.
Best,
Alvaro
