Executing the source geant4.sh shell script to set the G4 enviornment, it adds the /usr/lib/x86_64-linux-gnu on the LD_LIBRARY_PATH as
echo $LD_LIBRARY_PATH
/soft/geant/debug/lib:/usr/lib/x86_64-linux-gnu
When I try to launch libreoffice with this LD setting I get the error
/usr/lib/libreoffice/program/javaldx: error while loading shared libraries: libreglo.so: cannot open shared object file: No such file or directory
Warning: failed to read path from javaldx
/usr/lib/libreoffice/program/soffice.bin: error while loading shared libraries: libreglo.so: cannot open shared object file: No such file or directory
Removing the /usr/lib/x86_64-linux-gnu from the LD_LIBRARY_PATH, both geant and libreoffice are working fine.
Is it really needed this path?
