Hi, are there Geant4 toolkit examples that describe scintillators?, if so, what would those examples be?
The optical directory in the extended examples. The extended examples are generally focused on single broad topics.
Ok, thanks for your reply. Are the examples in the extended examples optical directory the only examples that describe scintillators as well as their material properties tables (optical properties)?
Those highlighted by @jrellin are the best ones to start with. There are a few other in the advanced examples, but if you are learning optical physics these are not a good starting point.
Ok, thanks. So, I´m going to start with the optical extended examples
