_Geant4 Version:_11.3.0
_Operating System:_ubuntu
Based on the suggestion under the relative question:How to get the name of parent particle that created the current track:
The purpose of getting the parent particle name for my code is to know the parent particle of produced gamma. so that I can draw different spectrum from different source respectively.
I develop the userTrackingInfo and stepping action corresponding function. Then I do something different from the Quote suggested-----I want to use UserTrackingaction to get parent particle name though track->GetUserInformation().
Then I meet some problems. I use TrackingAction
const G4ParticleDefinition* particle = track->GetParticleDefinition();
if (particle->GetParticleName() != "gamma") return;
G4VUserTrackInformation* rawInfo = track->GetUserInformation();
if (!rawInfo) {
G4cout << "[ERROR] No UserInformation for TrackID=" << track->GetTrackID() << G4endl;
G4String parentName = "unknown";
G4int parentID = -1;
if (musrTrackingInfo* trackInfo =static_cast<musrTrackingInfo*>(track->GetUserInformation())) {
parentName = trackInfo->GetParentName();
parentID = trackInfo->GetParentID();
}else{
if (track->GetParentID() == 0) {
parentName = "primary";
}else{
parentName="NoTrackingInfo";
musrTrackingInfo* trackInfo =static_cast<musrTrackingInfo*>(track->GetUserInformation());
G4cout << "[Gamma Tracking] TrackID: " << track->GetTrackID()
<< " | Parent: " << parentName
<< " (ID:" << parentID << ")"
<< G4endl;
I can make it successfully. But when run the .mac file, it will print out
[Gamma Tracking] TrackID: 3 | Parent: NoTrackingInfo (ID:-1)
[Gamma Tracking] TrackID: 2 | Parent: NoTrackingInfo (ID:-1)
Unknown particle: NoTrackingInfo
Showing that the gamma userInformation is not stored successfully.
As a reference for you, the following is the function I added in SteppingAction:
void musrSteppingAction::UserSteppingAction(const G4Step* aStep) {
G4Track* aTrack = aStep->GetTrack();
G4Track* currentTrack = aStep->GetTrack();
const std::vector<const G4Track*>* secondary = aStep->GetSecondaryInCurrentStep();
for (const G4Track* secondaryTrack : *secondary){
if (secondaryTrack->GetUserInformation()) continue;
// const G4int parentID = currentTrack->GetTrackID();
// const G4String& parentName = currentTrack->GetParticleDefinition()->GetParticleName();
// const G4double parentEnergy = currentTrack->GetKineticEnergy();
// const G4ThreeVector& parentMomentum = currentTrack->GetMomentum();
musrTrackingInfo* info = new musrTrackingInfo(
currentTrack->GetTrackID(),
currentTrack->GetParticleDefinition()->GetParticleName(),
currentTrack->GetKineticEnergy(),
secondaryTrack->SetUserInformation(info);
I have stuck in this question for a long time,![]()
Additionally,I also try other way,but it still does not work well.
Thanks!
Best,
Beining
