I have 2 methods to get the particle position at the end of a simulation step:
1.
G4ThreeVector position = track->GetPosition() - step->GetDeltaPosition();
2.
G4ThreeVector position = step->GetPostStepPoint()->GetPosition();
In my code, I invoke these 2 methods in SteppingAction::UserSteppingAction() method, but these 2 methods returns different results.
Are these 2 methods different?
_Geant4 Version:_4.11.0.p01
_Operating System:_windows subsystem linux (wsl2) Compiler/Version: CMake Version:
Yes, they calculate different things. When UserSteppingAction() is called, track->GetPosition() gives already the post-step point position. If you want them to give the same result, you do not need to substract the step delta position.
So in UserSteppingAction() any information from track, say, track->GetMomentum(), track->GetTotalEnergy(), track->GetPosition(),
will return identical result as from step->GetPostStepPoint->GetXXX(),
right?
Yes, that should be correct. My understanding is that step->GetDeltaPosition() is a “convenience function”, so you don’t have to manually do GetPostStepPoint()->GetPosition() - GetPreStepPoint()->GetPosition().
