G4Track* track = new G4Track;
auto creatorProcess = track->GetCreatorProcess();
if (G4Electron::ElectronDefinition() == aStep->GetTrack()->GetDefinition()){
if (creatorProcess->GetProcessName() == "LowEnergyIoni") {
cFile << edep << "\n";}
When i try to run it:
error: invalid use of incomplete type ‘const class G4VProcess’
58 | if (creatorProcess->GetProcessName() == "LowEnergyIoni") {
I am not sure how to fix it. I want to get the energy of particles that have been created by a specific process.
#include "G4VProcess.hh"
If you want to make use of the member functions of a class, you must include the class definition in your .cc file.
Oh. Thank you. Now it runs, but gives segmentation fault at terminal
You should check pointers to be sure they are not null before dereferencing them. Primary tracks, for example, do not have a creator process, so the pointer will be null.
if (creatorProcess && creatorProcess->GetProcessName() == ".....")
But your code is fundamentally broken. If you do
you are explicitly creating a brand new, empty object. You’re not accessing a track which is being propagated by Geant4 through your geometry. Of course all of its content is going to be empty, or zeroes, or null pointers.
I would highly recommend reading the Geant4 documentation to understand how the simulation works, and where and how in the code you write to access information.
