Excuse me if I specify wrong category. I don’t know which one is right category for such question.
Advise please a good C++ editor for GEANT4 where there was shown a list of variables and methods of certain class after writing “->”. I mean that I’m using Qt Creator and for example when I write G4ThreeVector Mom = aStep-> there no appears list of methods or variables. Also it’s desirable that in the recommended editor there highlighted errors.
when I write this, there is a list of stuff available. Do you have configured Geant4_DIR, and something equivalent to
# Find Geant4 package, activating all available UI and Vis drivers by default
# You can set WITH_GEANT4_UIVIS to OFF via the command line or ccmake/cmake-gui
# to build a batch mode only executable
option(WITH_GEANT4_UIVIS "Build example with Geant4 UI and Vis drivers" ON)
if(WITH_GEANT4_UIVIS)
else()
find_package(Geant4 REQUIRED)
endif()
# Setup Geant4 include directories and compile definitions
# Setup include directory for this project
include(${Geant4_USE_FILE})
VSCode is a good option, but like all editors/IDEs it requires learning and exploring the various extensions and settings to enable the functionality you’re after The docs are pretty helpful in getting things set up, e.g. see the C++ section for specifics like syntax highlighting and completion (“Intellisense” in general).
One tip with CMake is to configure your application with CMAKE_EXPORT_COMPILE_COMMANDS=ON. This produces a file which a lot of tools understand to look up paths and the like to find completions.
