I prepared a macro with the following instructions to simulate a double uniform source using GPS.
### First source
/gps/source/add 1.
/gps/particle e-
/gps/pos/type Plane
/gps/pos/shape Square
/gps/ene/mono 10 MeV
/gps/pos/centre 100 100 100 mm
/gps/pos/halfx 100 mm
/gps/pos/halfy 100 mm
/gps/direction 0 0 -1
### Second source
/gps/source/add 1.
/gps/particle e-
/gps/pos/type Plane
/gps/pos/centre 100 100 0 mm
/gps/direction 0 0 1
/gps/source/list
In contrast, it appears that some neutral particles are also launched as primary particles alongside electrons (here is an example, one green track originates at (0,0,0) and goes in -Z direction):
Is there something in the macro related to GPS that is missing?
The number of particle sources is: 3
Multiple Vertex sources: 0 Flat Sampling flag: 0
source 0 with intensity: 1
Num Particles: 1; Particle type: geantino
Energy: 1 MeV
Direction: (0,0,-1); Position: 0 0 0 fm
Angular Distribution: planar
Energy Distribution: Mono
Position Distribution Type: Point; Position Shape: NULL
source 1 with intensity: 1
Num Particles: 1; Particle type: e-
Energy: 1 MeV
Direction: (0,0,-1); Position: 10 10 10 cm
Position Distribution Type: Plane; Position Shape: Square
source 2 with intensity: 1
Energy: 1 MeV
Direction: (0,0,1); Position: 10 10 0 cm
