Greeting! Gods and Goddess of Geant4!
Now I stucked, so sad
Program based on B5
Carbon Ion through 2 sensitive detectors ( SD refine based on B5EmCalorimeterοΌ
But I only got 1 hit in each detector.
ProcessHits like below
G4bool B5EmCalorimeterSD::ProcessHits(G4Step*step, G4TouchableHistory*)
auto edep = step->GetTotalEnergyDeposit();
if (edep==0.) return true;
auto touchable = step->GetPreStepPoint()->GetTouchable();
auto motherPhysical = touchable->GetVolume(1); // 2022 5 11 mother
auto physical = touchable->GetVolume();
auto copyNo = physical->GetCopyNo();
auto motherCopyNo = touchable->GetVolume(1)->GetCopyNo();
auto hit = (*fHitsCollection)[copyNo];
G4int hit_num = 0;
// check if it is first touch
if (!(hit->GetLogV())) {
// fill volume information
hit->SetLogV(physical->GetLogicalVolume());
G4AffineTransform transform = touchable->GetHistory()->GetTopTransform();
transform.Invert();
hit->SetRot(transform.NetRotation());
hit->SetPos(transform.NetTranslation());
hit->SetPreEdep(edepPre_new);
hit->CalPreEdep(edepPre_new); // put in some compare num
auto worldPos = PreStep->GetPosition(); // absoluted position
auto localPos = touchable->GetHistory()->GetTopTransform().TransformPoint(worldPos); // relative coordinates
auto firstTouch_z = worldPos.z();
auto firstTouch_x = worldPos.x();
auto firstTouch_y = worldPos.y();
hit->SetWorldPos(worldPos);
hit->SetLocalPos(localPos);
// add energy deposition
hit->AddEdep(edep); // increment
return true;
My EventAction.cc like below
Now I cal nhit based on deposited, if deposited energy >0 , nhit + 1
But why the hit is only 1 ??
// tracker11 get data and write data
for (G4int iDet = 0; iDet < 1; ++iDet)
auto hc = GetHC(event, fCh_11_DigCal[0]);
if (!hc)
return;
G4cout << "hc : " << hc << G4endl;
// ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
// 2022 4 27
// nhit and deposited Energy - Init
totalCalHit[iDet] = 0;
totalCalEdep[iDet] = 0.;
for (unsigned long i = 0; i < hc->GetSize(); ++i)
G4double edep = 0.; // Init
G4double edepPre = 0.;
G4ThreeVector Primary_worldPos;
G4int count = 0;
// The EM and Had calorimeter hits are of different types
auto hit = static_cast<B5EmCalorimeterHit *>(hc->GetHit(i));
edepPre = hit->GetPreEdep();
edep = hit->GetEdep(); // deposited Energy
// 2022 4 27
// Energy > 0 ++
if ( edep > 0.)
totalCalHit[iDet]++; // nhit++
totalCalEdep[iDet] += edep; // depostied Energy
if ((edepPre > 0.))
Primary_worldPos = hit->GetECWorldPos();
auto nhit = hc->GetSize();
if (kPrintEventAction){
// εΌε
³ζεΌε°±ζε°
G4cout << "====================" << G4endl
<< " = Tracker 11 = " << G4endl
// << " Hits : " << hc->GetSize() << G4endl
<< " Input Energy (Ideal.)/MeV : " << edepPre << G4endl
<< " --- World (x,y,z) " << Primary_worldPos.x() << ", " << Primary_worldPos.y() << ", " << Primary_worldPos.z() << G4endl
<< "====================" << G4endl;
Ide_Edep_Tra11 = edepPre;
analysisManager->FillNtupleDColumn(5, (edepPre / MeV));
analysisManager->FillNtupleDColumn(6, Primary_worldPos.x());
analysisManager->FillNtupleDColumn(7, Primary_worldPos.y());
analysisManager->FillNtupleDColumn(8, Primary_worldPos.z());
// 2022 4 27
// nhits and deposited Energy
<< " = Tracker11 Accumulation Record = " << G4endl
<< " Hits : " << totalCalHit[0] << G4endl
<< " Deposit Edep/MeV : " << totalCalEdep[0]/MeV << " MeV"<< G4endl
Dep_Edep_Tra11 = totalCalEdep[0]/MeV;
nhit_Tra11 = totalCalHit[0];
analysisManager->FillNtupleDColumn(9, totalCalEdep[0]/MeV);
analysisManager->FillNtupleIColumn(10, totalCalHit[0]);
My problem is :
I wanna get total hits number in a detector, even include secondary particle.
that is to say, I wanna get the nhit of all cell of the sensitive detector
Help me plz!
Sincerely Thank Gods and Goddess of Geant4!
