When I try to run a simple Geant4 application https://github.com/jintonic/mingle/blob/main/mingle.cc in an interactive mode with GEANT4_DATA_DIR set to a wrong place, I’ll get the following error message:
*** G4Exception : PART70000
issued by : G4NuclideTable
G4ENSDFSTATEDATA environment variable must be set
Does Geant4 try to load datasets even at the Idle state? If datasets are truly optional, Can I get to the idle state without datasets?
Thanks,
Jing
