I have been modifying example B1, adding several additional logical volumes and incorporating the physics from TestEM1. I would now like to find out in which volumes gamma particles are generated by checking at each step if a gamma particle is generated. I modified B1SteppingAction as follows:
G4LogicalVolume* volume
= step->GetPostStepPoint()->GetTouchableHandle()
->GetVolume()->GetLogicalVolume();
// check if we are in scoring volume
//if (volume != fScoringVolume) return;
G4String volname = volume->GetName();
G4int ID = step->GetTrack()->GetParentID();
G4String particleName = step->GetTrack()->GetParticleDefinition()->GetParticleName();
G4double edepStep = step->GetTotalEnergyDeposit();
fEventAction->AddEdep(edepStep);
if (ID == 1 && particleName == "gamma"){
fEventAction->incrementSteps();
G4cout<<"gamma vol = " << volname << G4endl;
I then try to run the example with this code using a macro that generates 100 primary electrons. The incrementSteps statement counts up the number of gammas in each event. When the 2 lines with volname are commented out the output from the run indicates that 6 gammas are generated, found by filtering the run output with tracking verbose 1. The count is consistent with that. But when these lines are un-commented the program does not indicate any gammas generated.
Am I doing something wrong in attempting to get the volume corresponding to a gamma?
Edit: I think I found my problem. When checking each step for the volume name I was referencing the post step volume name. But in some cases the particle transports to “out of world” as its last step and has no post-step volume. My work-around was to check the volume name at the pre-step state and at least the program doesn’t crash and it seems to provide a reasonable result.
