Dear Geant4 experts,
How can I store the global time for each step of a trajectory in a HepRep file? I see that the positions of the steps are saved and some information about the trajectory when I use “/vis/scene/add/trajectories rich”. Also there is the possibility to add attributes but I don’t see how to do this for a step.
If you use /vis/scene/add/trajectories rich you get attributes as shown below (you should see this printing, but maybe you need /vis/verbose confirmations too). So global time is available for each step of the trajectory. (If you are in a magnetic field, you may miss some steps unless you /vis/scene/add/trajectories smooth rich.)
So global time should be available in HepRepFile (not HepRep nor HepRepXML). HepRepFile output is browsable with HepRApp - see documentation. The global time is certainly available to trajectory filtering commands and is used in “time slicing” - see documentation.
If you wish to add your own attributes, it can be done. It’s quite tricky so get back to me on that one.
Good luck
G4TrajectoriesModel:
Event ID (EventID): G4int
Run ID (RunID): G4int
G4RichTrajectory:
Creator Model ID (CMID): G4int
Creator Model Name (CMN): G4String
Creator Process Name (CPN): G4String
Creator Process Type Name (CPTN): G4String
Ending Process Name (EPN): G4String
Ending Process Type Name (EPTN): G4String
Final kinetic energy (FKE): G4BestUnit (G4double)
Final Next Volume Path (FNVPath): G4String
Final Volume Path (FVPath): G4String
Track ID (ID): G4int
Initial Next Volume Path (INVPath): G4String
Initial Volume Path (IVPath): G4String
No. of points (NTP): G4int
PDG Encoding (PDG): G4int
Parent ID (PID): G4int
Particle Name (PN): G4String
G4RichTrajectoryPoint:
Process Defined Step (PDS): G4String
Process Type Defined Step (PTDS): G4String
Position (Pos): G4BestUnit (G4ThreeVector)
Post-step-point status (PostStatus): G4String
Post-step-point global time (PostT): G4BestUnit (G4double)
Post-step Volume Path (PostVPath): G4String
Post-step-point weight (PostW): G4double
Pre-step-point status (PreStatus): G4String
Pre-step-point global time (PreT): G4BestUnit (G4double)
Pre-step Volume Path (PreVPath): G4String
Pre-step-point weight (PreW): G4double
Remaining Energy (RE): G4BestUnit (G4double)
Total Energy Deposit (TED): G4BestUnit (G4double)
Hello John,
Thank you very much for your answer. I don’t quite understand how I can save the global time for each step in a HepRep file by applying filters. I can filter by charge and plot/save a specific one but how do I do that with the global time? I don’t want to filter out a trajectory just save the time in addition to the location. Could you tell me what commands to use or where to find them?
Hello John,
I basically just need an xml or txt file with x,y,z position, time, type of particle and its energy. It needs to be a file as I will then pass it on to another programme running on a different operating system. There the event should be visualized in a slow motion sequence. For this visualization I need a simple xml or txt file. I had hoped that the HepRep format might offer this directly.
Could I ask you if you know of an example where such information is stored in an xml or txt format?
With kind regards
Clemens
Hello John,
I have found a suitable solution for me. Using these three commands in vis.mac, the global time per step for each particle is also stored in a HepRep file.
