Geant4 Version: 11.2.2
Operating System: Ubuntu 24.04.4 LTS
Compiler/Version: GCC 13.3.0
CMake Version: 3.28.3
Title: How should I model a rotating phantom with inserts using G4RotationMatrix?
I have a PMMA cylindrical phantom that is placed in the world. Inside the phantom I have an aluminium cylinder and an iron cylinder acting as inserts.
Currently, I simulate phantom rotation by keeping the PMMA phantom fixed and manually changing the positions of the Al and Fe cylinders. For each projection angle, I calculate their coordinates as
x = x_center + r*cos(theta);
y = y_center + r*sin(theta);
This approach produces the desired geometry, but I am wondering whether this is the recommended way to model a rotating phantom in Geant4.
I have also experimented with G4RotationMatrix, but I am confused about how rotations are defined. My phantom has already been rotated (e.g. by 90° to make its cylindrical axis vertical), so its local coordinate system is no longer aligned with the world coordinate system.
My questions are:
Are the position and rotation supplied to
G4PVPlacementalways interpreted in the mother volume’s local coordinate system, or are rotations defined with respect to the world axes? -
If I want the Al and Fe cylinders to rotate around the centre of the PMMA phantom while remaining daughters of the phantom, should I update both their positions and their rotation matrices?
Instead of moving the inserts manually, is it possible (and preferable) to rotate the entire PMMA phantom using a
G4RotationMatrixso that all daughter volumes rotate automatically withconstruction.cc (13.2 KB)
it?
What is the recommended Geant4 approach for modelling a rotating phantom with internal inserts for projection simulations?
I would appreciate any guidance on the best practice for this type of geometry.
