How to calculate air kerma in Geant4?
I am using Geant4 to simulate an X-ray imaging system, and I would like to calculate the air kerma at the detector entrance surface.
The X-ray source is a polychromatic X-ray spectrum, and I need to use the simulated air kerma to calibrate the number of photons emitted by the source against an experimentally measured air kerma.
I understand that Geant4 does not seem to provide a standard kerma scorer. What is the recommended way to calculate air kerma in Geant4 for a polychromatic X-ray beam?
Should I calculate it from the photon fluence and the mass energy-transfer coefficient of air, or can I obtain it by scoring the energy transferred to secondary electrons in an air volume?
Thank you for your help.
Geant4 Version: 10.07
I found this paper by looking it up. See whether it takes you in the right direction
https://www.sciencedirect.com/science/article/pii/S135044870800334X
Cheers,
/Pico
