I wanted to execute run1.mac of example B1 in Windows, I used the command start exampleB1.exe run1.mac and one page I thought to be correct showed up but exited 1 second later. Am I doing it correctly and how can I see the output of run1.mac?
Thank you very much.
Siyao
I’m facing this only when something is wrong with the code. Then everything stops and quits immediately.
But I’m running a macro e.g. via ***.exe /run.mac if this helps?
***.exe /run.mac
It worked, thank you.
