How to find Decay time and Rise Time?
Hi, Everyone,
I hope this message finds you well.
I am currently working on an optical simulation using Geant4 (version 4.11). In my setup, I am irradiating a LYSO scintillation crystal with 511 keV gamma photons, which generates optical photons. These optical photons are subsequently detected by a silicon-based SiPM. During the simulation, I am tracking several parameters, including energy deposit, wavelength, global time, and local time.
My focus is on analyzing the global time to extract both the decay and rise times by applying a bi-exponential fit. However, I am encountering some challenges with the fitting process. Specifically, the chi-squared value of the fit is excessively large, and the second rise time appears to be shorter than the first.
I am attaching reference images that illustrate the expected data, as well as my current output for your review. Any advice or suggestions on resolving these issues would be greatly appreciated.
Thank you in advance, and I look forward to your responses.
Reference image.
Screenshot from 2024-10-24 11-04-34
Output image.
_Geant4 Version:_11.2.0
_Operating System:_Ubuntu 22.04.4
_Compiler/Version:_11.4.0
CMake Version: 3.22.1
I would find a way to understand the HUGE count at bin 0 close to 2e4. That one for sure is skewing your fit.
/Pico
p.s: for this fitting issue you are welcome to try the ROOT forum as well.
Thanks pico for responding. So it’s not the problem with my simulation. if i share my root macro ro you can you please suggest me the solution.
I am not an expert in ROOT, but it is clear that chi-squared is most affected by the largest values. To remove the bias, one must calculate chi-squared relative to the absolute value for the point. Also, there are too many 1 sample points that do not improve the fit.
Thanks @phirippu for responding i am unable to find the solutions how i can remove one sample points that’s appearing near zero. Can you please give some suggestions about this.
The bin count at zero points to an issue of your simulation setup. There is simply not enough information to help with that. How is this fit being generated? There are endless analysis packages out there in many languages. It should be straight forward to mask the histogram to remove both the outlier at 0 or bins with counts below some threshold.
I suspect the paper also did a weighted fit. A good diagnostic would be to recreate the plot at the bottom which shows the residuals across the bins.
You also must remove the big value bias. I think you should not use ROOT for the analysis if removing one point does not seem easy. There are indeed many tools for this kind of analysis; use the one you are most familiar with. You can also ask ChatGPT if you are looking for a code example.
Hello, Rehmaniftikhar
I am doing the same thing now. I would like to know why there are two taus (τ1, τ2) for the fitted curves. Are they for the fast component and the slow component? Also, how can the emission curve of photons be simulated?
Hi SkylerGH,
Yes, the two taus (τ1, τ2) represent the fast and slow decay and rise components. To simulate the emission of photons, you should define the optical properties of your material in the detector construction class. In addition, you must register for the OpticalPhysics class in your Physics class. Once you define the optical properties of your material and register the OpticalPhysics class, you can check the production of optical photons in your sensitive volume.
Many thanks for your reply, Rehmaniftikhar! As you suggest, I need to get the GlobalTime of photons in a scintillator and fit the GlobalTime with an exponential function. I wonder if I need to filter some photons produced by the reflection process when I get the GlobalTime of photons in a scintillator.
I think if you do not put any conditions on the production level, you can get all the photons produced into the scintillator. But if you want to filter photons produced by reflections, you can do it. There will be an option for reflections; as I am not an expert on Geant4, I don’t know if it is necessary or not. Also, I don’t know for what application you are doing the simulation so its not possible for me to guide more.
Thanks again, Rehmaniftikhar! By the way, is the Reference image you post from a published paper? Could you share the link of that paper?
