I am new to using geant4 and cmake, and am trying to compile my first program that I have written. I have the source code (geant4-10.7.1) downloaded on linux and have it built too. The problem I am having is with my cmake lists file for my cpp main file, which is in the following format:
Project name and cmake requirement.
project(geant4sim)
cmake_minimum_required(VERSION 2.6)
Find and configure geant4.
option(WITH_GEANT4_UIVIS “Build example with Geant4 UI and Vis drivers” ON)
if(WITH_GEANT4_UIVIS)
else()
find_package(Geant4 REQUIRED)
endif()
Configure project to use geant4 and project headers.
include({Geant4_USE_FILE}) include_directories({PROJECT_SOURCE_DIR}/include)
List sources to build the project.
file(GLOB sources {PROJECT_SOURCE_DIR}/src/*.cc) file(GLOB headers {PROJECT_SOURCE_DIR}/include/*.hh)
Define and link the executable.
add_executable(geant4sim main.cpp {sources} {headers})
target_link_libraries(main ${Geant4_LIBRARIES})
Copy runtime scripts to the build directory.
set(MAIN_SCRIPTS
main.in
main.out
init_vis.mac
run1.mac
run2.mac
vis.mac
foreach(_script {MAIN_SCRIPTS})
configure_file(
{PROJECT_SOURCE_DIR}/{_script}
{PROJECT_BINARY_DIR}/${_script}
COPYONLY
endforeach()
Install executable.
install(TARGETS geant4sim RUNTIME DESTINATION bin)
This is basically the same format as the example I found under the book for application developers for how to make the cmake file, but I am getting the error from the find and configure geant4 step:
Could not find a package configuration file provided by “Geant4” with any
of the following names:
Geant4Config.cmake
geant4-config.cmake
Add the installation prefix of “Geant4” to CMAKE_PREFIX_PATH or set
“Geant4_DIR” to a directory containing one of the above files. If “Geant4”
provides a separate development package or SDK, be sure it has been
installed.
I don’t know how to make the Geant4_DIR to be where the config file is, which is under the geant4-10.7.1-build. I believe I have to add it to the CMakeLists file, but I am not sure of the syntax, since I am not very familiar with cmake.
Thanks for any help or ideas!
