How to get dose rates on other side of shielding?
I have a neutron source on one side of rectangular water shielding. How can I get the dose rates due to neutrons and photons on the other side of the shielding? I have the geometry setup and generate primaries (see attached) but I am unaware how to get the dose rates?
Is there a particular example I can look into? Ideally, I would like to overlay a mesh right outside of the shielding and get the dose rates in each voxel in mrem/h or uSv/h.
you can use scoring volume to see the dose deposition. You can also get a csv data file for this.
you can take the help from the basic example B1 . in this it calculates dose.
how can generate two gamma of different energy in exampleB1 ? And calculate dose rate for these two gamma in material ?
Hi, you can generate two gamma rays in the same event.
cheers
You can try using the macro command “score” for this.
score.txt (1.3 KB)
