Hi all,
I have a source that emitted proton particles. I would like to store information of each particle (position, particle type, energy, direction, …) to a root file (Ntuple type). I have created a GPS source via macro.
I think we can get the information of each primary particle at BeginOfEventAction(const G4Event*) method. That is correct?
Can anyone help me please? Thank you in advance.
Look at G4PrimaryVertex which contains the primary position information, and contains a list (vector) of G4PrimaryParticle which contains the kinematics. G4Event provides an accessor for the list (vector) of G4PrimaryVertex instances in the event.
Hi @mkelsey,
Thank you for your help.
Here is my code. Could you help me to check it? Thank you in advance.
G4int evtID = evt->GetEventID();
G4PrimaryParticle* priPar = evt->GetPrimaryVertex()->GetPrimary();
G4String parName = priPar->GetParticleDefinition()->GetParticleName();
G4double parCharge = priPar->GetCharge();
G4double parEng = priPar->GetKineticEnergy();
G4ThreeVector parPos = priPar->GetMomentum();
G4ThreeVector parDir = priPar->GetMomentumDirection();
G4cout << "Event ID: " << evtID
<< " Par name: " << parName
<< " , Charge: " << parCharge
<< " , Energy: " << parEng/MeV << "MeV"
<< " , Position: " << "(" << parPos.getX() << ", " << parPos.getY() << ", " << parPos.getZ() << ")"
<< " , Direction: " << "(" << parDir.getX() << ", " << parDir.getY() << ", " << parDir.getZ() << ")"
<< G4endl;
// get analysis manager
analysisManager->FillNtupleIColumn(6, 0, evtID);
analysisManager->FillNtupleSColumn(6, 1, parName);
analysisManager->FillNtupleIColumn(6, 2, parCharge);
analysisManager->FillNtupleDColumn(6, 3, parEng);
analysisManager->FillNtupleDColumn(6, 4, parPos.getX());
analysisManager->FillNtupleDColumn(6, 5, parPos.getY());
analysisManager->FillNtupleDColumn(6, 6, parPos.getZ());
analysisManager->FillNtupleDColumn(6, 7, parDir.getX());
analysisManager->FillNtupleDColumn(6, 8, parDir.getY());
analysisManager->FillNtupleDColumn(6, 9, parDir.getZ());
analysisManager->AddNtupleRow(6);
parPos is not a position. You’re filling it with the full momentum vector (in units of MeV) from the kinematics.
