I have been able to add the QGSP_INCLXX (G4HadronPhysicsINCLXX) but I would like to update it to the QGSP_INCLXX_HP physics, the problem is that I cannot find the properly way of introducing it to this example. I’d appreciate any advice.
Hi, thank you for your prompt reply and suggestion
It worked nicely and I was able to load the default configurarion for QGSP_INCLXX_HP. I was wondering where I could see the EM physics, Ion physics… (that I was able to manage within PhysicsList.cc to build any configuration) for this precompiled physics when calling from the main.
I suggest to look directly in the code, in $PATH_TO_GEANT4/source/physics_lists/lists. EMPhysicsConstructor , some parameters like the cut can be changed via UI commands. Please refer to the doc. What I usually do (it is just my method) is to copy the physics list in my application and change it as I like it.
