Hi everyone, I want to increase simulation performance by stopping tracking gamma particles, electrons, and positrons (kill them) when their energies drop below some defined energy E (MeV). This doesn’t seem to work with the SetCut() method as I find it just sets a different threshold for secondary particle formation than I would like. So how can I do this?
In SteppingAction :
G4Track* track = (G4Track*)(step->GetTrack());
G4double Ekin = track->GetKineticEnergy();
if (Ekin < Emin) track->SetTrackStatus(fStopAndKill);
Thank you for your help. I will try it. Have a good day.
maybe you could gain additional performance by replacing the string comparisons with
if (step->GetTrack()->GetParticleDefinition() == G4Gamma::Gamma())
as the stepping action is called for literally every step of the simulation.
Can I do the same with electrons and positrons?
if (step->GetTrack()->GetParticleDefinition() == G4Electron::Electron)
if (step->GetTrack()->GetParticleDefinition() == G4Positron::G4Positron)
sure, that should work perfectly. alternatively:
switch (track->GetParticleDefinition() )
case G4Gamma::Gamma():
if (Ekin < Emin_gamma) track->SetTrackStatus(fStopAndKill);
break;
case G4Electron::Electron():
break;
case G4Positron::G4Positron():
break;
In complement to @weller remarks :
1- I realized that cast is not necessary here. It is enough to write :
G4Track* track = step->GetTrack();
2- better to write :
const G4double Emin_gamma = 10*keV; etc …
with const, Emin_gamma is initialized only once and never modified.
there is two issues, the easy one:
#include "G4Gamma.hh"
#include "G4Electron.hh"
#include "G4Positron.hh"
the hard one: apparently the switch-case construction does not accept track->GetParticleDefinition(). Sorry I brought this up, thought this would work. Apparently, switch-case is more than just replacing a series of if-elseif-elseif stuff
Easiest is to revert to what you suggested (but you still have to include the classes):
const G4ParticleDefinition* particleDefinition = track->GetParticleDefinition();
if (particleDefinition == G4Electron::Electron())
else if (particleDefinition == G4Positron::Positron())
Thank you very much, I understood the problem and fixed the code according to your instructions. I wish you a good day.
Another point : as the name of the function tell, Ekin is the kinetic energy of the particle, not its total energy.
Do you really want to kill electrons of kinetic energy = 521 keV ?
Dear Sir, I am simulating Geant4 and comparing the results with MCNP. In MCNP I use the CUT:p and CUT:e cards to set an energy threshold for tracking individual particles. So I just want to put the same condition for two simulation cases.
