How to make pencil beam radius
Hello experts!
How to make pencil beam radius?
How to correct my code ?
Help please!
void SimpleParticleSource::GeneratePrimaries(G4Event* anEvent)
G4double radius = 0.4*cm;
G4double phi = 360.*deg;
    G4double rRan = radius*(G4UniformRand());
    G4double phiRan = phi*(G4UniformRand());
    G4double z0 = -6.8*cm;
fParticleGun->SetParticlePosition(G4ThreeVector(rRancos(phiRan)-9.18cm,rRan*sin(phiRan),z0));
if(flag) fParticleGun->GeneratePrimaryVertex(anEvent);
the way your code generates coordinates inside the disk oversamples positions close to the center.
I would recommend to use general particle source gps instead, there you can configure the shape to be a circle of desired radius.
Do you mean using macro file ? I don’t understand
yes, using macro is what I had in mind. There are probably several examples shipped with geant4, and also this: Geant4 GPS Examples
regarding the statement of oversampling at the center: math - Generate a random point within a circle (uniformly) - Stack Overflow
I don’t use macro file.
    G4double u = G4UniformRand() + G4UniformRand();
    G4double rRan = radius*(( u>1) ? 2-u : u);
    G4double phiRan = phi*G4UniformRand();
    fParticleGun->SetParticlePosition(G4ThreeVector(rRan*cos(phiRan)-9.18*cm,rRan*sin(phiRan),z0));
@weller Why do you set u = G4UniformRand()+G4UniformRand() rather than simply u = 2*G4UniformRand()? I don’t think it fundamentally matters for the distribution, but I’m curious.
honestly — no clue. found the code snipped in there and switched off brain:
edit: they do a vivid discussion about the differences though!
Thanks, @weller ! From the StackOverflow comments:
Try using both schemes to generate random numbers and see what you get. 2*random() gives numbers uniformly distributed in the range 0 to 2. random()+random() gives you numbers in the range 0 to 2 but there will (usually) be more numbers near 1.0 than near 0.0 or 2.0. It’s like how rolling two dice and summing is more likely to give 7 than any other number.
I need to think about this. We do something entirely different, generating differential area elements:
  G4double rho = Rmax * sqrt(G4UniformRand());
  G4double phi = twopi * G4UniformRand();
  G4TwoVector point; point.setPolar(rho, phi);
the two approaches seem equally valid in result, yours is also mentioned in that StackOverflow discussion: Disk Point Picking -- from Wolfram MathWorld
maybe the performance (Sqrt vs. 2nd random throw) is the difference then?
edit: depends on the generator, for the ones available in matlab sqrt is faster.
Ah, you may be right. Naively, I would have expected a random generator to be more expensive than sqrt(), but possibly not.
to finally come back to the topic: if you want to avoid introducing macro files to your simulation, you can also issue commands in source code like this:
  G4UImanager* UImanager = G4UImanager::GetUIpointer();
  UImanager->ApplyCommand("/gps/pos/type Plane");
  UImanager->ApplyCommand("/gps/pos/shape Circle");
  UImanager->ApplyCommand("/gps/direction 0 0 1");
  UImanager->ApplyCommand("/gps/pos/centre -9.18 0. -6.8. cm");
  UImanager->ApplyCommand("/gps/pos/radius 0.4 cm");
Thank You so much! It works
Hello!
How to rotate the circular plane source 30 degrees to axes X and 60 degrees to axes Z ?
(I mean the particles must interact with material by the form of circle not a elliptic which we see on the picture).
    G4double radius = 1.5*cm;
    G4double x0 = -9.18*cm;
fParticleGun->SetParticlePosition(G4ThreeVector(x0,rRansin(phiRan),rRancos(phiRan)+z0));
fParticleGun->SetParticleMomentumDirection(G4ParticleMomentum(cos(30.0deg),cos(90.0deg),cos(60.0*deg)));
one way is to calculate the rotated base vectors and issue the commands /gps/pos/rot1 and /gps/pos/rot2, see
https://geant4-userdoc.web.cern.ch/UsersGuides/ForApplicationDeveloper/html/GettingStarted/generalParticleSource.html#source-direction-and-angular-distribution
