Now I have checked all parameters of G4ScreenedNuclearRecoils, and It can produce PKA same as SRIM output, but I come across another problem: The PKA(Au recoil atom) with enough energy(for example, 100eV) can NOT produce any secondary recoils.
Which process can generate recoils under condition that 100eV Au ion irradiate100nm Au thin foil? SRIM output shows there are about 2.7 recoils/ion when ion energy is 100eV. But Geant4 code can’t produce any recoils when I use G4ScreenedNuclearRecoil as main physics process. The process counter gives result that G4ScreenedNuclearRecoil has been called once for most of ion, but no recoils been produced.
Is there anyone knows why? Should I change step length or any other parameters?
Do you have the Geant4 “production cuts” set? We are very interested in nuclear recoils in our experiment as well, so we have our physics list configured with the “proton” production cut (which applies to all hadrons) set to 1e-9 mm. If you have the default 1 mm value set, then you’ll essentially never see a nuclear recoil, since the nuclei aren’t going to travel that far.
Yes, nuclei are made of baryons, a subset of hadrons.
I’m surprised nothing has changed. Are you saying that there are no recoil secondaries produced? Or are you saying that you don’t see recoil tracks in the visualization?
Thanks for your attention!
I tried just now to set cut to zero, the output didn’t change at all. Even if I changed cut to a very high value(like 1000000nm), the Au recoils number still didn’t change.(But the electron secondaries changed, that means the cut setting works).
I think there must be something else wrong.
