How to reduce process verbosity
I want to remove this annoying messages that I see in output during every program execution:
CoulombScat:  for pi-, integral:1  SubType=1 BuildTable=1
Used Lambda table of pi+
ThetaMin(p) < Theta(degree) < 180; pLimit(GeV^1)= 0.139531
===== EM models for the G4Region  DefaultRegionForTheWorld ======eCoulombScattering : Emin=    0 eV  Emax=  100 TeV
                  HADRONIC PROCESSES SUMMARY (verbose level 1)
                           Hadronic Processes for B-
  Process: hadElastic
        Model:              hElasticLHEP: 0 eV  ---> 100 TeV
     Cr_sctns:            Glauber-Gribov: 0 eV  ---> 100 TeV
  Process: B-Inelastic
        Model:                      FTFP: 0 eV  ---> 100 TeV
I tried this:
int main(int argc,char** argv)
G4HadronicProcessStore * hps = G4HadronicProcessStore::Instance();
hps->SetVerbose(0);
but it does not work
Another vain attempt was a UI command: /process/had/verbose 0
***** Illegal application state </process/had/verbose 0> *****
*** G4Exception : UIMAN0123
Command aborted (200)
Error code : 200
Is there any ways to handle with it?
when a PhysicsList is instantiated all parameters of the Physics List are reset. So, these parameters (like verbose level) should be changed after instantiation of a Physics List.
Application states in Geant4 : G4State_PreInit - before initialization of geometry and physics; G4State_Init - initialization phase; G4State_Idle - geometry and physics are initialized and Geant4 is ready to start run.
To suppress initialization verbosity you need apply UI command or C++ set method at PreInit stage when Physics List is already instantiated.
VI
Where exactly should I write it in order to success?
You can look my code here: GitHub - artem-phys/TmCryst: Geant4 Monte Carlo simulation of proposed axion search experiment with Tm2Al5O12 bolometric crystal in a cryogenic facility
I am also suffered from this problem. Have you solved it?
You need to use “/process/had/verbose 0” after you have created your physics list, but before the run initialization (i.e. before you use either “/run/initialize” or the “Initialize()” method of the run manager).
I found this worked:
after initialization of the physics list
theRunManager->SetUserInitialization(myPhyList);
then call
G4HadronicProcessStore::Instance()->SetVerbose(0);
Hello, did you finally found a way to solve this ? I’m experiencing the same issue
Thank by advance,
GC
In case it helps, the verbosity level can be passed as a parameter to the PhyscisList constructor. If you don’t want any output from the physics list just instantiate it like this example:
int verboseLevel = 0; // set to zero for non-verbosity
G4VModularPhysicsList* phys = new QGSP_BERT_HP(verboseLevel);
