Hello, I have been trying to rotate the logical volumes (array of white hollow cylinders in the attached figure) after replicating it using the G4PVReplica. How can I rotate the cylinders shown in the figure? I want to rotate it along the x-axis by 90 degrees. But not sure how can I incorporate rotation after the replication of logical volumes! Any help would be appreciated.
#include "DetectorConstruction.hh"
DetectorConstruction::DetectorConstruction()
DetectorConstruction::~DetectorConstruction()
// Material Information imported from NIST database
G4Material* Air = nist->FindOrBuildMaterial("G4_AIR");
G4Material* Water = nist->FindOrBuildMaterial("G4_WATER");
// Polystyrene (C8H8)n
G4Material* Pstyrene = new G4Material("Polystyrene", 1.03*g/cm3, 2);
Pstyrene->AddElement(nist->FindOrBuildElement("C"), 8);
Pstyrene->AddElement(nist->FindOrBuildElement("H"), 8);
// Print all the materials defined.
G4cout << G4endl << "The materials defined are : " << G4endl << G4endl;
G4cout << *(G4Material::GetMaterialTable()) << G4endl;
// Define a World Volume
G4VSolid* solidWorld = new G4Box("solidbox", 120*mm,120*mm,120*mm); // half length of sides
G4LogicalVolume* logicWorld = new G4LogicalVolume(solidWorld, Air, "logicWorld");
G4VPhysicalVolume* physWorld = new G4PVPlacement(0, // no rotation of daughter frame wrt mother frame
G4ThreeVector(), // position in mother volume at (0,0,0)
logicWorld, // logical volume
"physWorld", // name
0, // mother volume
false, // no boolean operation, set it to false
0, // copy number, unique arbitary number
true); // optional overlap check
// Define outer box
G4VSolid* outerbox = new G4Box("phantombox", 63.88*mm, 7.3*mm, 42.74*mm); //half length of cell well
G4LogicalVolume* logicCell_well = new G4LogicalVolume(outerbox, Pstyrene, "logicCell_well"); // logical volume - assign properties to object material
G4VPhysicalVolume* fPhantomPhysOuter = new G4PVPlacement(0,
G4ThreeVector(),
logicCell_well, "fPhantomPhysOuter", // physical voloume - place the created object in the coordinate system of mother volume
logicWorld, false, 0);
// Visualization attributes -- outer box
// logicWorld->SetVisAttributes(G4VisAttributes::GetInvisible()); // world volume box will dissappear
// G4VisAttributes* outerBoxVisAtt= new G4VisAttributes(G4Colour(1, 1, 1)); // white volume
// outerBoxVisAtt-> SetVisibility(true);
// outerBoxVisAtt-> SetForceSolid(true);
// logicCell_well-> SetVisAttributes(outerBoxVisAtt);
// Define inner box
G4VSolid* innerbox = new G4Box("innerBox", 46.0*mm, 5.09*mm, 32.74*mm);
G4LogicalVolume* logicCell_well_inner = new G4LogicalVolume(innerbox, Pstyrene, "logicCell_well_inner");
G4VPhysicalVolume* fPhantomPhysInner = new G4PVPlacement(0,
G4ThreeVector(0., 2.545*mm, 0.),
logicCell_well_inner,
"fPhantomPhysInner",
logicWorld,
false, 0);
// Visualization attributes -- inner box
// G4VisAttributes* innerBoxVisAtt= new G4VisAttributes(G4Colour(1, 1, 0));
// innerBoxVisAtt-> SetVisibility(true);
// innerBoxVisAtt-> SetForceSolid(true);
// logicCell_well_inner-> SetVisAttributes(innerBoxVisAtt);
// // Subtract inner box from outer box
G4VSolid* solidShape = new G4SubtractionSolid("outer-inner",
outerbox,
innerbox,
0, // no rotation
G4ThreeVector(0*mm, 0*mm, 0*mm)); // no translation
G4LogicalVolume* logicCellWell = new G4LogicalVolume(solidShape, Pstyrene, "logicCellWell", 0, 0, 0);
G4VPhysicalVolume* physCellWell = new G4PVPlacement(0,
G4ThreeVector(0, 0, 0),
logicCellWell,
"physCellWell",
logicWorld, // its mother volume
true, // Boolean operation
0, false); // check overlaps
// Visualization attributes -- subtracted volume
G4VisAttributes* cellwellVisAtt= new G4VisAttributes(G4Colour(1.0, 0.0, 0.0)); // red color
cellwellVisAtt-> SetVisibility(true);
cellwellVisAtt-> SetForceSolid(false);
logicCellWell->SetVisAttributes(cellwellVisAtt);
// Construct cells_wells (hollow cylinders with outer thickness of 5 mm and inner 4.5 mm and height 9.18 mm
G4Tubs* cylinder = new G4Tubs("hollow_cylinder", 4.5*mm, 5*mm, 10.8*mm, 0., 360*degree);
G4LogicalVolume* logicCylinder = new G4LogicalVolume(cylinder, // its name
Water, // material
"logicCylinder", // in place of "logicWorld", cylinder->GetName() also works
0, 0, 0); // FieldManager, SensitiveDetector, ULimits
// Rotate logical volumes by 90 degrees in X-axis
G4RotationMatrix* replicatedCylinder= new G4RotationMatrix;
replicatedCylinder-> rotateX(90.*deg);
// Let us use G4Replica to create a array of hollow cylinders
G4PVReplica* physHollowCylinder = new G4PVReplica(cylinder->GetName(), // its name ("hollow_cylinder")
logicCylinder, // its logical volume
logicCell_well_inner, // its mother logical volume (innerbox, length 46*2 =92 mm)
kXAxis, // axis of replication
9, // # of Replicas
10.0*mm, // width of replica (9*10.0 = 90.0 < 92 mm, OK), this width is equal to the diameter of cylinder/well
0); // offset
// G4VPhysicalVolume* physHollowCylinder;
// physHollowCylinder = new G4PVPlacement(replicatedCylinder, G4ThreeVector(0.*mm, (5.09+0.61)*mm, 0.*mm),
// logicCylinder, "physHollowCylinder",
// logicWorld, false, 0);
// Visualization of cylinders
G4VisAttributes* CylinderVisAtt= new G4VisAttributes(G4Colour(1, 1, 1));
CylinderVisAtt-> SetVisibility(true);
CylinderVisAtt-> SetForceSolid(true);
logicCylinder-> SetVisAttributes(CylinderVisAtt);
return physWorld;
