Hello everyone, I am interested to run 2000 macrofiles. I made a bash script, but have too many files. I can put these in a folder and compile. I do not how to compile these macros.
I tried
./example /folder/macro.mac also
./example folder/macro.mac
However, the last ones did not function. Someone who can help me I will thank a lot!
If your executable looks at argv[1] for the macro name, then you should be able to provide whatever path to the macro file you want. If your executable doesn’t support reading in macro files, that could be your problem.
Yup. And the “fileName” string can include whatever path you need to actual find the file. Of course, it has to be the correct path, relative to your current working directory.
