Hello Experts,
I want to know that how to score dose at any point of detector geometry ?
How can i do this ?
Thanks in advance!
Priyanshu
You should define a sensitive volume. There are different ways to do that. The easiest way is via a scoring mesh. I think here you find a good description: https://indico.cern.ch/event/782305/contributions/3256028/attachments/1793321/2922301/2c_Scoring.pdf
Thank you for your reply !
is the sensitive volume and fscoring volume same ? as fscoring is used in the example B1.
Examples B4 illustrate various ways to extract and register informations. See Readme.
- B4a : direct UserActions. Also used in B1 and B4b.
- B4c : sensitive detectors + hits collections. Also used in B2 and B5.
- B4d : scorers. Also used in B3.
Notice that examples in extended/electromagnetic and hadronic use UserAction approach.
You may need to read :
Tracks and steps — FrequentlyAskedQuestions 10.7 documentation
