Hello, dear Geant4 experts and users!
I created the scintillator via G4Box and used G4PVPReplica to create a 100x100 array. I set the scintillator to SensitiveDetector and do the evaluation in SD.cc.
- When a photon deposits EnergyDeposit, the code increases the position count by +1.
I can see that the results are stored correctly when calculating with a single core, but when calculating with multithreading, the results are stored strangely.
I think there is an error in each thread calculating and aggregating the results, can you help?
This is my SensitiveDetector.cc
SensitiveDetector::SensitiveDetector(G4String name)
: G4VSensitiveDetector(name)
ofs.open(“Serial_Test.txt”);
for(G4int i=0; i<100; i++)
for(G4int j=0; j<100; j++)
DEMatrix[i][j] = 0;
SensitiveDetector::~SensitiveDetector()
ofs << DEMatrix[i][j] << " ";
ofs << “\n”;
ofs.close();
void SensitiveDetector::Initialize(G4HCofThisEvent *)
G4bool SensitiveDetector::ProcessHits(G4Step *aStep, G4TouchableHistory *)
G4int RepYNo = aStep->GetPreStepPoint()->GetTouchable()->GetReplicaNumber(0);
RepPixel_Y = RepYNo;
G4int RepXNo = aStep->GetPreStepPoint()->GetTouchable()->GetReplicaNumber(1);
RepPixel_X = RepXNo;
G4double dE = aStep->GetTotalEnergyDeposit();
Deposit_E += dE;
if (Deposit_E > 0.0)
DEMatrix[RepPixel_Y][RepPixel_X] += 1;
return true;
void SensitiveDetector::EndOfEvent(G4HCofThisEvent *)
