Dear Geant4 users,
How to activate multithread when running geant4.11.0.2 examples?
For example when the following command is applied:
/run/numberOfThreads 2
(also with change number 2).
It did not work and the following error appeared:
***** Illegal application state </run/numberOfThreads 2> *****
*** G4Exception : UIMAN0123
Command aborted (200)
Error code : 200
I think (but not sure) the error come from the cmake compiling that appear in compiling (my cmake version is cmake-3.5.0-rc3) and the follwing line appeared :
Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failedas
the following is all terminal output :
The C compiler identification is GNU 9.3.0
– The CXX compiler identification is GNU 9.3.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found suitable version “2.2.9”, minimum required is “2.2.9”)
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Check if compiler accepts -pthread
– Check if compiler accepts -pthread - yes
– Found Threads: TRUE
– Found XercesC: /usr/lib/x86_64-linux-gnu/libxerces-c.so (found suitable version “3.2.2”, minimum required is “3.2.2”)
– Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
– Found X11: /usr/include
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Found Geant4: /home/username/geant4.11/install_g4/lib/Geant4-11.0.2/Geant4Config.cmake (found version “11.0.2”)
– Configuring done
– Generating done
– Build files have been written to: example
