Hi
I’m recently learning to use phase space files, but I have some questions about the SetZStop(G4double zValue) function.
I added the relevant file to my B1 program, and then called the SetZStop(G4double zValue) function in BeginOfRunAction.
The official manual describes this function as follows: it defines a new scoring plane at z = zValue. This method must be called at least once before the Geant4 run starts.
At first I set this parameter to 10cm, in this case I can only launch one particle, if I launch more than one particle the program will quit. If I set this parameter to 90cm, then I can launch more particles.
I never quite understand this question and would like to ask you how this function should be used if I want to generate my own phase space file.
Thank you all for your replies
Dear Jodie,
Could you please provide more details regarding the class of that method, phase-space format, what the “relevant file” is, etc.?
Regards,
Miguel
hi mcortes:
Thank you for your reply, I am sorry I did not describe it clearly, the relevant documents refer to the following documents.
• iaea_config.h
• iaea_header.h and iaea_header.cc
• iaea_phsp.h and iaea_phsp.cc
• iaea_record.h and iaea_record.cc
• utilities.h and utilities.cc
These files are some dependency files and changes to the B1 program only appear in RunAction, Event Action, Stepping Action.Here is my program
void RunAction::BeginOfRunAction(const G4Run*aRun)
// inform the runManager to save random number seed
G4RunManager::GetRunManager()->SetRandomNumberStore(false);
// reset accumulables to their initial values
G4AccumulableManager* accumulableManager = G4AccumulableManager::Instance();
accumulableManager->Reset();
G4IAEAphspWriter*IAEAWriter = G4IAEAphspWriter::GetInstance();
IAEAWriter->SetZStop(90.*cm);
IAEAWriter->SetFileName("test");
IAEAWriter->BeginOfRunAction(aRun);
void RunAction::EndOfRunAction(const G4Run* aRun)
G4IAEAphspWriter::GetInstance()->EndOfRunAction(aRun);
void EventAction::BeginOfEventAction(const G4Event*aEvent)
fEdep = 0.;
G4IAEAphspWriter::GetInstance()->BeginOfEventAction(aEvent);
void SteppingAction::UserSteppingAction(const G4Step* aStep)
G4IAEAphspWriter::GetInstance()->UserSteppingAction(aStep);
Thanks for your reply.
Cheers!
