I am trying to run the basic B1 example but running into some problem
_Geant4 Version:_11.2.1
_Operating System:_macOS
_Compiler/Version:_Apple Clang 15.0.0
_CMake Version:_3.30.2
—I am getting the following error
(base) bikashchauhan@Bikashs-MacBook-Air B1 % cmake .
– Configuring done (0.2s)
– Generating done (0.0s)
– Build files have been written to: /Users/bikashchauhan/GEANT/test_HandsOn1/B1
(base) bikashchauhan@Bikashs-MacBook-Air B1 % make -j 2 -f Makefile
/opt/homebrew/Cellar/cmake/3.30.2/bin/cmake -S/Users/bikashchauhan/GEANT/test_HandsOn1/B1 -B/Users/bikashchauhan/GEANT/test_HandsOn1/B1 --check-build-system CMakeFiles/exampleB1.dir/build.make CMakeFiles/exampleB1.dir/build
[ 25%] Building CXX object CMakeFiles/exampleB1.dir/exampleB1.cc.o
[ 25%] Building CXX object CMakeFiles/exampleB1.dir/src/ActionInitialization.cc.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4VIS_USE_OPENGLQT -DG4VIS_USE_OPENGLX -DG4VIS_USE_QT3D -DG4VIS_USE_TOOLSSG_QT_GLES -DG4VIS_USE_TOOLSSG_QT_ZB -DG4VIS_USE_TOOLSSG_X11_GLES -DPTL_BUILD_DLL -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_WIDGETS_LIB -I/Users/bikashchauhan/GEANT/test_HandsOn1/B1/include -isystem /Users/bikashchauhan/GEANT/install/include/Geant4 -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/System/Library/Frameworks -isystem /opt/homebrew/anaconda3/include/qt -isystem /opt/homebrew/anaconda3/include/qt/QtGui -isystem /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/anaconda3/include/qt/QtCore -isystem /opt/homebrew/anaconda3/./mkspecs/macx-clang -isystem /opt/homebrew/anaconda3/include/qt/QtOpenGL -isystem /opt/homebrew/anaconda3/include/qt/QtWidgets -isystem /usr/X11R6/include -isystem /opt/homebrew/include -std=gnu++17 -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk -fPIC -MD -MT CMakeFiles/exampleB1.dir/src/ActionInitialization.cc.o -MF CMakeFiles/exampleB1.dir/src/ActionInitialization.cc.o.d -o CMakeFiles/exampleB1.dir/src/ActionInitialization.cc.o -c /Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4VIS_USE_OPENGLQT -DG4VIS_USE_OPENGLX -DG4VIS_USE_QT3D -DG4VIS_USE_TOOLSSG_QT_GLES -DG4VIS_USE_TOOLSSG_QT_ZB -DG4VIS_USE_TOOLSSG_X11_GLES -DPTL_BUILD_DLL -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_WIDGETS_LIB -I/Users/bikashchauhan/GEANT/test_HandsOn1/B1/include -isystem /Users/bikashchauhan/GEANT/install/include/Geant4 -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/System/Library/Frameworks -isystem /opt/homebrew/anaconda3/include/qt -isystem /opt/homebrew/anaconda3/include/qt/QtGui -isystem /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/anaconda3/include/qt/QtCore -isystem /opt/homebrew/anaconda3/./mkspecs/macx-clang -isystem /opt/homebrew/anaconda3/include/qt/QtOpenGL -isystem /opt/homebrew/anaconda3/include/qt/QtWidgets -isystem /usr/X11R6/include -isystem /opt/homebrew/include -std=gnu++17 -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk -fPIC -MD -MT CMakeFiles/exampleB1.dir/exampleB1.cc.o -MF CMakeFiles/exampleB1.dir/exampleB1.cc.o.d -o CMakeFiles/exampleB1.dir/exampleB1.cc.o -c /Users/bikashchauhan/GEANT/test_HandsOn1/B1/exampleB1.cc
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/exampleB1.cc:30:
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/DetectorConstruction.hh:33:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4VUserDetectorConstruction.hh:41:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh:35:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh:35:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh:74:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex:236:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:321:In file included from 5/Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc::31:
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hh: 34:
In file included from error: /Users/bikashchauhan/GEANT/install/include/Geant4/G4ParticleGun.hh:54 tried including <math.h> but didn’t find libc++'s <math.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex# error tried including <math.h> but didn’t find libc++'s <math.h> header. :
236:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:321:5: error: tried including <math.h> but didn’t find libc++'s <math.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
error tried including <math.h> but didn’t find libc++'s <math.h> header. \
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:588:17: error: expected unqualified-id
return std::isnan(__lcpp_x);
/Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include/math.h:166 return std::isnan(__lcpp_x);:
5: ^
note: expanded from macro ‘isnan’
( sizeof(x) == sizeof(float) ? __inline_isnanf((float)(x))
/Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include/math.h:166:5: note: expanded from macro ‘isnan’
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc:31:
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hhIn file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/exampleB1.cc:30:
In file included from :34:
/Users/bikashchauhan/GEANT/install/include/Geant4/G4VUserDetectorConstruction.hhIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4ParticleGun.hh41::
54In file included from :
/Users/bikashchauhan/GEANT/install/include/Geant4/globals.hhIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh35::
35In file included from :
/Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hhIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh35::
/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hhIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh74::
74In file included from :
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complexIn file included from :/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex236::
236:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath608::60817::17 : error: error: expected unqualified-idexpected unqualified-id
return std::isinf(__lcpp_x);
/Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include/math.h: ^
161:5:/Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include/math.h :161:note: 5:expanded from macro ‘isinf’
note: expanded from macro ‘isinf’
( sizeof(x) == sizeof(float) ? __inline_isinff((float)(x))
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc:In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh:35:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh:3135:
In file included from In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hh/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh::3474:
In file included from In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4ParticleGun.hh/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex::54236:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath::35724:
:In file included from 15/Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh:: 35:
In file included from error: /Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh:74no template named ‘numeric_limits’:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:724 return -numeric_limits<_Tp>::infinity();:
15: ^
error: no template named ‘numeric_limits’
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:728:14: error: no template named ‘numeric_limits’/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:
728:14: error: return numeric_limits<_Tp>::infinity();
no template named ‘numeric_limits’ ^
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:731:14: error: no template named ‘numeric_limits’
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:731:14: return numeric_limits<_Tp>::quiet_NaN();
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:735:19: error: no template named ‘numeric_limits’
while (__x >= numeric_limits<_Tp>::radix) {
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:736:14: error: no template named ‘numeric_limits’
__x /= numeric_limits<_Tp>::radix;
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:759:14: error: no template named ‘numeric_limits’
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:763:16: error: no template named ‘numeric_limits’
__mult = numeric_limits<_Tp>::radix;
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:768:17: error: no template named ‘numeric_limits’
__mult /= numeric_limits<_Tp>::radix;
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:834:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/type_traits:425:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/add_pointer.h:17:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/remove_reference.h:13:
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstddef::3146:
:In file included from 5/Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hh:: 34:
In file included from error: /Users/bikashchauhan/GEANT/install/include/Geant4/G4ParticleGun.hh:54 tried including <stddef.h> but didn’t find libc++'s <stddef.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.:
error tried including <stddef.h> but didn’t find libc++'s <stddef.h> header. \
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstddef:46:5: error: tried including <stddef.h> but didn’t find libc++'s <stddef.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstddef:59:9: error: no member named ‘nullptr_t’ in the global namespace
using ::nullptr_t;
using ::nullptr_t;
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hh:34:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4ParticleGun.hh:54:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh:35In file included from :
/Users/bikashchauhan/GEANT/test_HandsOn1/B1/exampleB1.ccIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh30::
/Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/DetectorConstruction.hhIn file included from :/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex33::
236In file included from :
/Users/bikashchauhan/GEANT/install/include/Geant4/G4VUserDetectorConstruction.hhIn file included from :/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:834:
In file included from 41:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/type_traits:456:35:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_compound.hIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh14::
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_fundamental.hIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh14::
74:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_null_pointer.h::23626:
:In file included from 28/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:: 834:
In file included from error: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/type_traits:456use of undeclared identifier ‘nullptr_t’; did you mean ‘nullptr’?:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_compound.h:14:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_fundamental.h:14:
struct __is_nullptr_t_impl<nullptr_t> : public true_type {};
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_null_pointer.h ^:
26:28: error: use of undeclared identifier ‘nullptr_t’; did you mean ‘nullptr’?
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_null_pointer.h:26:28: struct __is_nullptr_t_impl<nullptr_t> : public true_type {};
error: ^
template argument for template type parameter must be a type
error: ^
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_null_pointer.h:23:17: struct __is_nullptr_t_impl<nullptr_t> : public true_type {};
note: template parameter is declared here
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_null_pointer.htemplate :
23: ^17
: note: template parameter is declared here
template
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/exampleB1.ccIn file included from :/Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc30::
31In file included from :
/Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/DetectorConstruction.hhIn file included from :/Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hh33::
34In file included from :
/Users/bikashchauhan/GEANT/install/include/Geant4/globals.hhIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh35:35:
In file included from /Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh:35/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh:74:
:In file included from 74/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex:
:In file included from 236/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex:
:In file included from 236/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:
:In file included from 834/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmath:
:In file included from 834/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/type_traits:
:In file included from 508/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/type_traits:
:In file included from 508/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_trivially_copyable.h:
:In file included from 14/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/__type_traits/is_trivially_copyable.h:
:14/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstdint:
:149/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstdint::5149:: 5: error: error: tried including <stdint.h> but didn’t find libc++'s <stdint.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case. tried including <stdint.h> but didn’t find libc++'s <stdint.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
error tried including <stdint.h> but didn’t find libc++'s <stdint.h> header. # error tried including <stdint.h> but didn’t find libc++'s <stdint.h> header. \
In file included from In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/exampleB1.cc/Users/bikashchauhan/GEANT/test_HandsOn1/B1/src/ActionInitialization.cc::3031:
In file included from /Users/bikashchauhan/GEANT/test_HandsOn1/B1/include/PrimaryGeneratorAction.hhIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh34::
/Users/bikashchauhan/GEANT/install/include/Geant4/G4ParticleGun.hhIn file included from :54:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complexIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/globals.hh238::
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/stdexceptIn file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4ios.hh48::
35/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstdlib:90::
5In file included from :/Users/bikashchauhan/GEANT/install/include/Geant4/G4Types.hh :74:
error: In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/complex: tried including <stdlib.h> but didn’t find libc++'s <stdlib.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.238:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/stdexcept:48:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstdlib:90:5: # error tried including <stdlib.h> but didn’t find libc++'s <stdlib.h> header.
error: ^
error tried including <stdlib.h> but didn’t find libc++'s <stdlib.h> header. \
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstdlib:132:9: error: target of using declaration conflicts with declaration already in scope
using ::abs _LIBCPP_USING_IF_EXISTS;
/Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include/stdlib.h:132:6:/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cstdlib:132:9: error: target of using declaration conflicts with declaration already in scope
note: target of using declaration/Library/Developer/CommandLineTools/SDKs/MacOSX14.4.sdk/usr/include/stdlib.h
:132:6: int abs(int) __pure2;
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++note: /v1/cmath:target of using declaration354:
1: note: int abs(int) __pure2;conflicting declaration
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.5.sdk/usr/include/c++/v1/cmathusing ::abs _LIBCPP_USING_IF_EXISTS;:
354:^1
: note: conflicting declaration
