Dear all
I am trying to include the IAEA phase space files Writer funcionalities in my Geant 4 application.
I have done all modifications on RunAction, Event Action and SteppingAction files according to the manual, and also I have include all IAEA Phase-space database files to my source and iclude folder. As I am running Geant4 11.1 version, I have also made some modification on the G4IAEAphspWriter.cc file to correct some errors in compilation.
I have some warnings on my compilation:
/Users/alessandratomal/Documents/Radboudumc/voxmammo-master/monte_carlo/include/utilities.h:83:9: warning: ‘LITTLE_ENDIAN’ macro redefined [-Wmacro-redefined]
#define LITTLE_ENDIAN __LITTLE_ENDIAN
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.0.sdk/usr/include/arm/endian.h:71:9: note: previous definition is here
#define LITTLE_ENDIAN __DARWIN_LITTLE_ENDIAN
In file included from /Users/alessandratomal/Documents/Radboudumc/voxmammo-master/monte_carlo/sources/iaea_phsp.cc:68:
/Users/alessandratomal/Documents/Radboudumc/voxmammo-master/monte_carlo/include/utilities.h:84:9: warning: ‘BIG_ENDIAN’ macro redefined [-Wmacro-redefined]
#define BIG_ENDIAN __BIG_ENDIAN
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.0.sdk/usr/include/arm/endian.h:72:9: note: previous definition is here
#define BIG_ENDIAN __DARWIN_BIG_ENDIAN
/Users/alessandratomal/Documents/Radboudumc/voxmammo-master/monte_carlo/include/utilities.h:85:9: warning: ‘PDP_ENDIAN’ macro redefined [-Wmacro-redefined]
#define PDP_ENDIAN __PDP_ENDIAN
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.0.sdk/usr/include/arm/endian.h:73:9: note: previous definition is here
#define PDP_ENDIAN __DARWIN_PDP_ENDIAN
I can run the executable, but even If I used a single calculation mode, the resulting files IAEAphsp file was empty.
I included score planes and several points of the geometry, where I am sure that there is transport of particles and none is recorded. See example below
Phase-space file at z = -1.78e-16 cm closed successfully!
NEW PHASE SPACE FILE WILL BE CREATED
IAEA_INDEX: 1000
TITLE: PHASESPACE in IAEA format
FILE TYPE: PHASESPACE
RECORD LENGTH: 33
RECORD_CONTENTS:
// Variable 3 is constant
// 1 extra LONG variable(s) defined
// Incremental history number stored in the extralong array [ 0]
RECORD_CONSTANT:
0.0000 // Constant variable # 3
NUMBER OF PRIMARY PARTICLES: 1000
PARTICLES: 0
GLOBAL_PHOTON_ENERGY_CUTOFF: 0.00000
GLOBAL_PARTICLE_ENERGY_CUTOFF: 0.00000
Is it can be related to the warnings? I am using a MacBook M2.
