hello
Can I simulate IBD(Inverse Betta decay ) Process in geant4?
thanks
In principle you could, if you wrote the process yourself, but this wouldn’t make much sense, as (anti)neutrino interactions are very rare: you don’t have to spend ages of CPU time to track neutrinos and have only a few interactions.
The usual way to handle this problem is by using a primary generator: you directly generate the final state of the IBD (i.e. the positron and the neutron) by an appropriate algorithm and you feed this as the “initial state” of a Geant4 simulation.
Thank you,
I know P.Vogel has done something about it. Regarding the angular cross section of IBD. In addition, I found packages that do this, such as NuMC or RATpac, but I do not have access to these packages. Do you have another solution?
Uh, no. I don’t have any other alternative solution than implementing the code yourself, if you cannot get a ready-for-the-use implementation…
I seem to have to make something myself
Hi! I know it’s been a while since you have posted, but I am also interested in simulating IBD. Did you find any good resource afterwards?
You may have seen this article:
NuSD: Neutrino Segmented Detector is a Geant4-based user application that simulates inverse beta decay events in a variety of segmented scintillation detectors developed by different international collaborations.
