I would like to enable PIXE (very time consuming) only for few G4Region of my geometry.
I noticed that in the Geant4 class processes/electromagnetic/utils/src/G4VAtomDeexcitation.cc, the method AlongStepDeexcitation() is called by processes/electromagnetic/utils/src/G4VEnergyLossProcess.cc only if the useDeexcitation parameter is enabled, i.e. only if the PIXE effect is turned on in the PhysicsList with:
G4EmParameters* param = G4EmParameters::Instance();
param->SetPixe(true);
Therefore, it is mandatory to set the PIXE parameter = “true” in order to access the AlongStepDeexcitation() method.
On the other hand, looking at the first lines of AlongStepDeexcitation method:
G4VAtomDeexcitation::AlongStepDeexcitation(std::vector<G4Track*>& tracks,
const G4Step& step,
G4double& eLossMax,
G4int coupleIndex)
G4double truelength = step.GetStepLength();
if(!flagPIXE && !activePIXEMedia[coupleIndex]) { return; }
the method is skipped only when both the parameters flagPIXE and activePIXEMedia[coupleIndex] are false. But flagPIXE=true if “param->SetPixe(true)” is used in the above PhysicsList.
Therefore the activePIXEMedia[coupleIndex], that defines the active G4Region, is ignored in the condition and the AlongStepDeexcitation() is executed even if the region is not active (i.e., if activePIXEMedia[coupleIndex]=false).
In my opinion the correct condition should use “||” instead of “&&”:
if(!flagPIXE || !activePIXEMedia[coupleIndex]) { return; }
or simply
if(!activePIXEMedia[coupleIndex]) { return; }
because AlongStepDeexcitation() is called only when flagPIXE=true
Is it correct?
Geant4 Version: 10.7.3
I am confused about what it is you need to do. Continuing with:
You can activate PIXE for select regions using
G4Region* pixeLogReg = (G4RegionStore::GetInstance())->GetRegion("pixeLogReg");
param.SetDeexcitationActiveRegion("pixeLogReg");
Where “pixeLogReg” here is a G4Region that contains all the volumes that you want to activate PIXE (here, slide 33). G4regions can include any number of logical volumes including different materials.
Is it correct?
I suspect that it is that way because of the expectation that you would use that method to activate/deactivate PIXE.
Yes, I confirm that I use SetDeexcitationActiveRegion to activate PIXE only in my Target region:
param.SetDeexcitationActiveRegion("DefaultRegionForTheWorld", true, true, false);
param.SetDeexcitationActiveRegion("Target", true, true, true);
In this case, I would expect PIXE to be active only for the “Target” region, but it seems not to work and PIXE is always executed.
As previously said, I think that the problem is in the G4VAtomDeexcitation::AlongStepDeexcitation(), which is the Geant4 method implementing PIXE.
Indeed, this method is always executed when PIXE is enabled in G4EmParameters by
even if the particle is outside of the active G4Region.
It can be deduced from the if statement at the beginning of the AlongStepDeexcitation() method:
where flagPIXE is always true, due to the above statement:
You are grabbing the EMoptions instance and then setting its parameters. It will set PIXE in your target region and everywhere else. I think there may be an inadvertent race condition depending on where you are doing this. I have used this before in my physics list file. Try replacing:
with
G4EmProcessOptions param;
param.SetPIXE(true);
And then set the region using it. You’ll need to include G4EmProcessOptions.hh
Hi, Justin. If the OP is quoting the in-process check correctly, then I think they’re right:
is equivalent to
if (flagPIXE || activePIXEMedia[coupleIndex]) {
do all the process stuff...
which reads, at least to me, like it’ll go through if the global flag is set, even if the per-region flag is false.
Yes, this is the point.
Moreover, it is important to underline that it is mandatory to set the global flag flagPIXE=true to enable PIXE: only in this case the PIXE libraries and code are called.
Therefore, the per-region flag activePIXEMedia[coupleIndex], whatever its value, is completely ignored by Geant.
Just an update.
I changed ‘&&’ to ‘||’ in the if statement and repeated the simulation:
New condition in G4VAtomDeexcitation::AlongStepDeexcitation(),:
The result is consistent with the previous one obtained with ‘&&’ and the simulation was about 100 times faster in my case. Therefore I think that this is a bug that should be corrected in Geant4.
Could you open a bug report?
