Geant4 Version: 11.2.2
Operating System: Linux
I’m trying to set up a simulation that records hits and the only error I have is whenever I include G4VHit.hh, which causes hundreds of errors to appear in files outside what I’ve edited.
Here are some of these errors that I’m getting.
/usr/include/c++/13/bits/stl_list.h: At global scope:
/usr/include/c++/13/bits/stl_list.h:631:49: error: ‘allocator’ in namespace ‘B4::std’ does not name a template type; did you mean ‘uses_allocator’?
631 | template<typename _Tp, typename _Alloc = std::allocator<_Tp> >
| uses_allocator
/usr/include/c++/13/bits/stl_list.h:631:58: error: expected ‘>’ before ‘<’ token
/usr/include/c++/13/bits/stl_list.h:644:21: error: ‘is_same’ was not declared in this scope; did you mean ‘std::is_same’?
644 | static_assert(is_same<typename remove_cv<_Tp>::type, _Tp>::value,
| std::is_same
/usr/include/c++/13/type_traits:709:12: note: ‘std::is_same’ declared here
709 | struct is_same;
/usr/include/c++/13/bits/stl_list.h:644:38: error: expected nested-name-specifier before ‘remove_cv’
Is there a way to get around this or am I able to not include G4VHit.hh and still have my code work?
