Hello Experts,
I am trying to fill a Ntuple with total energy deposited in a given detector. I tried modifying example B5/B4c for this.
I gave a condition to sore the energy if its greater than around 0.1 MeV, however still I am getting a large peak at 0 upon plotting the histogram. Manually inspecting the TTree values also reveal there are many 0 entries.
Can someone please share what I am messing here ?
Here are the relevant parts of application
- Creating ntuples
B1RunAction::B1RunAction() {
analysisManager->SetVerboseLevel(1);
analysisManager->SetNtupleMerging(true);
analysisManager->CreateNtuple("B4", "Edep");
analysisManager->CreateNtupleDColumn("Eabs");
analysisManager->FinishNtuple();
- Opening root files
void B1RunAction::BeginOfRunAction(const G4Run*)
G4String fileName = "B4";
analysisManager->OpenFile(fileName);
- Filling NTuples (User Eventaction class)
void B1EventAction::EndOfEventAction(const G4Event* event)
// get analysis manager
//Calorimeter Hits
array<G4int, kDim> totalCalHit = {{ 0 }};
array<G4double, kDim> totalCalEdep = {{ 0. }};
for (G4int iDet = 0; iDet < kDim; ++iDet) {
auto hc = GetHitsCollection(fCalHCID[iDet], event); //kdim =1
if ( ! hc ) return;
totalCalHit[iDet] = 0;
totalCalEdep[iDet] = 0.;
for (unsigned long i = 0; i < hc->GetSize(); ++i){
G4double edep = 0.;
if (iDet == 0) { // idet = 0 means calorimeter detector
auto hit = static_cast<B2TrackerHit*>(hc->GetHit(i));
edep = hit->GetEdep();
/*else { //only used when more than one detector type
if ( edep > 0. ) {
totalCalHit[iDet]++;
totalCalEdep[iDet] += edep;
fCalEdep[iDet][i] = edep;
if (totalCalEdep[iDet] > 100*keV)
G4cout << "Fill Energy" << totalCalEdep[iDet] << G4endl;
analysisManager->FillNtupleDColumn(0, totalCalEdep[iDet]); }//totoal enrgy in one type of detector
analysisManager->AddNtupleRow();
I think that the condition if (totalCalEdep[iDet] > 100*keV)
should only add energies above 100keV, this is also also evident from the G4cout dump. But when I see the ntuple it has entries less than 100keV as well.
The co60 spectrum shows a high peak at 0 as well.
Thanks in advance !
Edit 1: Just went through this post and found a similar kind of issue. I am not sure but my best guess is that perhaps the Ntuples are getting initialised by 0 values
If i just comment analysisManager->FillNtupleDColumn(0, totalCalEdep[iDet]);
The spectrum looks like
