Incorrect output energy using LEND
I have done some more testing and found this affects other reactions that have 2+ bodies in the output, for example, Li6(n,a)H3, which also has incorrect output energy like the B10(n,a)Li7 reaction.
To make it more familiar, I used example Hadr03 for better reproducibility, here is the result using QGSP_BIC_HP and ShieldingLEND with B10 isotope target:
Hadr03 example output using QGSP_BIC_HP:
The run is 100000 neutron of 1e-05 eV through 10 m of B10 (density: 2.46 g/cm3 )
Process calls frequency:
nCapture= 12 neutronInelastic= 99988
MeanFreePath: 344.06 nm ± 343.1 nm massic: 0.084638 mg/cm2
CrossSection: 29065 cm^-1 massic: 11815 cm2/g
crossSection per atom: 1.9645e+05 barn
Verification: crossSections from G4HadronicProcessStore:
nCapture= 1.5336 cm2/g 25.499 barn
neutronInelastic= 11785 cm2/g 1.9595e+05 barn
total= 11787 cm2/g 1.9598e+05 barn
List of nuclear reactions:
neutron + B10 → N gamma or e- + B11: 12 Q = 13.066 MeV
neutron + B10 → N gamma or e- + alpha + Li7: 93670 Q = 2.7904 MeV
neutron + B10 → alpha + Li7: 6318 Q = 2.7901 MeV
number of gamma or e- (ic): N = 1 → 5
List of generated particles:
B11: 12 Emean = 3.7641 keV ( 1.3211 keV → 6.4208 keV)
Li7: 99988 Emean = 851 keV ( 831.89 keV → 1.0143 MeV)
alpha: 99988 Emean = 1.4916 MeV ( 1.4716 MeV → 1.7772 MeV)
gamma: 169268 Emean = 265.43 keV ( 1.0001 keV → 11.456 MeV)
Momentum balance: Pmean = 28.836 keV ( 853.5 eV → 82.715 keV)`
Hadr03 example output using ShieldingLEND:
nCapture= 18 neutronInelastic= 99982
MeanFreePath: 350.66 nm ± 349.85 nm massic: 0.086262 mg/cm2
CrossSection: 28518 cm^-1 massic: 11593 cm2/g
crossSection per atom: 1.9275e+05 barn
nCapture= 1.5126 cm2/g 25.15 barn
neutronInelastic= 11624 cm2/g 1.9328e+05 barn
total= 11626 cm2/g 1.933e+05 barn
neutron + B10 → N gamma or e- + B11: 18 Q = 13.604 MeV
neutron + B10 → N gamma or e- + alpha + Li7: 93810 Q = 5.3463 MeV
neutron + B10 → alpha + Li7: 6172 Q = 5.3461 MeV
number of gamma or e- (ic): N = 1 → 4
B11: 18 Emean = 4.7141 keV ( 260.61 eV → 14.003 keV)
Li7: 99982 Emean = 1.7796 MeV ( 1.7688 MeV → 1.9424 MeV)
alpha: 99982 Emean = 3.1186 MeV ( 3.0998 MeV → 3.4038 MeV)
gamma: 93854 Emean = 479.99 keV ( 477.6 keV → 11.456 MeV)
Momentum balance: Pmean = 448.04 keV ( 0.03038 eV → 477.6 keV)
We can see from the cross section summary and number of alpha+Li7 particles produced that the cross section data of G4NDL and LEND are the same. Just the issue of incorrect Q and kinetic energy in the output products.
I have found the cause of the issue by looking at the XML files in the LEND data folders. I found in LEND_GND1.3_ENDF.BVII.1/neutrons/005_B_010/005_B_010.000.xml at approximately line 400 under “Program DICTIN”, it has the definition of the particles with their mass and energy states:
However in the GIDI source files of Geant4, located under source/particles/management/src/MCGIDI_mass.cc,
it has the atomic masses of the nuclei stated, but with different values for alpha and Li7:
We see that the LEND XML data files has alpha=4.0015 amu and Li7=7.0143 amu, while GIDI has them stated again as alpha=4.0026 amu and Li7=7.0160 amu. After I edited the LEND XML file for B10 to have the same particle mass as GIDI, LEND started behaving as expected, with the same result as BIC_HP and literature:
Hadr03 example output using ShieldingLEND AFTER changing LEND XML data file:
neutron + B10 → N gamma or e- + alpha + Li7: 93810 Q = 2.7896 MeV
neutron + B10 → alpha + Li7: 6172 Q = 2.7897 MeV
Li7: 99982 Emean = 850.62 keV ( 839.9 keV → 1.0134 MeV)
alpha: 99982 Emean = 1.4909 MeV ( 1.4721 MeV → 1.7762 MeV)
Momentum balance: Pmean = 448.04 keV ( 0.03036 eV → 477.6 keV)
This fix also corrects other two body output reactions such as Li6(n,a)H3.
Discussion:
The GND1.3 data file used by LEND (the XML file) is the same as one that can be downloaded from the ENDF website for the desired reactions. It also has the different mass definitions for alpha and Li7. If an older evaluation is used, such as ENDF6 the GND file has the same particle masses as GIDI_mass.
I believe that there may have been some slight correction that was made to the GND file to apply a correction, but this hasn’t been realised in the LEND model of Geant4.
My guess is that the GIDI processor for the LEND data files was originally made for ENDF6 and wasn’t updated after some ‘correction’ was made to the GND data file for ENDF7. So when the neutronInelastic process happens, the energy conservation cannot be calculated properly due to different definitions of the particle masses.
What does everyone else think?
This is a major issue that needs to be addressed by the LEND development team. (I have submitted bug report 2300 but haven’t heard back yet).
