Hello, I have a question about the installation of data files. I have already installed Geant4.11 but i need now the new data file G4EMLOW8.0 to be able to run my example that needs the sigma_elastic_e_elsepa_Z79_muffintin.dat file. I have already download the G4EMLOW8.0.tar.gz and I just need to know how to update the old one (G4EMLOW7.13) or replace it.
Thank you
If you did a G4 install, it “should” (depending on your CMake option settings) have taken care of that for you automatically. Otherwise, you can do it by hand as follows:
- Source the geant4.sh script as usual.
- Get the value of the
$G4LEDATAenvvar, which specifies the directory where it’s looking for the G4EMLOW stuff. -
cdto the parent directory; for example, ifG4LEDATA = /Applications/GEANT4/data/G4EMLOW8.0, then you wouldcd /Applications/GEANT4/data - Do
tar -zxf /path/to/your/G4EMLOW8.0.tar.gz. This will unpack the data into a G4EMLOW8.0 directory, right where G4 is looking for it.
you could also try the commands
geant4-config --check-datasets
to check install status and location, and
geant4-config --install-datasets
to install missing datasets.
You can see how long I’ve been using G4 – I’m still doing stuff the old manual way, not even realizing that there are helpful utilities provided now.
Thanks a lot for your answers but i had to solve my problem quickly yesterday so i reinstalled geant4 with right datasets and everything works. However, your answers could help me for possible future problems.
Thank you and have a nice day.
