Installation of GEANT4 Ubntu
I am a new user and I am trying to install Geant4 and I encountred this error while executing the make install command
. Can someone please help me as I am a bit new and I have no idea how to correct it?
You included the option -DCMAKE_INSTALL_PREFIX=/home/Documents/PASA/geant4-v11.1.0-install in your cmake command. Do you have such a directory on your system? If you don’t, and you don’t have permissions to create directories under /home, then you should do your installation to a different directory path that you do have permissions for.
I creaded the directory, so it is there on my system. I am still not able to install. Don’t understand why…
What are the read/write permissions on /home/Documents/PASA/geant4-v11.1.0-install, i.e. what do the commands
$ ls -ld /home/Documents
$ ls -ld /home/Documents/PASA
$ ls -ld /home/Documents/PASA/geant4-v11.1.0-install
print?
You are right, it needed speacial permission. I now created a new folder without needed special permission and it works fine there. Thank you.
