Installation of Planetocosmics v2 (on Alamlinux 9)
Hi all,
I’ve spent quite a time trying to install Planetocosmics v2 (http://cosray.unibe.ch/~laurent/planetocosmics/). So I’ve made brief an installation guide for Almalinux 9 that worked for me.
For now I will just leave it here:
Installation of planetocosmics 2.0 on Alamlinux 9 (64-bit) from (bash) terminal (with root)
Almalinux 9 config. for install:
(Probably none of these is important, but I used these configs.)
Software selection: workstation
	(+ internet applications)
	(+ remote desktop clients)
	(+ container management)
	+ development tools
	(+ graphical administration tools)
	+ scientific support
KDUMP disabled (for memory save)
Install root (the version was 6.26.10, it seems to work fine with planetocosmics):
sudo dnf install epel-release
sudo dnf install root
sudo dnf install root-cli
Install cshell, gfortran
sudo dnf update
sudo dnf install tcsh
sudo dnf install gcc-gfortran
Create software directory in the $HOME directory:
cd
mkdir software
Save the current bash_profile, just in case…
cp .bash_profile bash_profile_copy
Install clhep in software directory (2.0.2.3 seems to work fine with geant4 8.1.2):
cd
cd software/
wget https://proj-clhep.web.cern.ch/proj-clhep/dist1/clhep-2.0.2.3.tgz
tar -zxvf clhep-2.0.2.3.tgz
wget https://geant4-forum.web.cern.ch/uploads/short-url/aDsk4ChOgPy5c5sI0psHLHpVwFr.txt -O clhep.patch
cd 2.0.2.3
patch -p1 < ../clhep.patch
cd ../
mv 2.0.2.3 clhep_2.0.2.3_src
mkdir clhep_2.0.2.3_install
cd clhep_2.0.2.3_src/CLHEP
./configure --prefix=$HOME/software/clhep_2.0.2.3_install/
make
make check
make install
cd
echo "" >> .bash_profile
echo "# Add CLHEP to library path" >> .bash_profile
echo "export LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:\$HOME/software/clhep_2.0.2.3_install/lib/" >> .bash_profile
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/software/clhep_2.0.2.3_install/lib/
Install geant4 8.1.2
cd
cd software/
wget https://gitlab.cern.ch/geant4/geant4/-/archive/v8.1.2/geant4.8.1.2.tar.gz
tar -zxvf geant4.8.1.2.tar.gz
wget https://geant4-forum.web.cern.ch/uploads/short-url/8URDH7Saa2cJQvmb2KuB5dI8Lxh.txt -O geant4.patch
cd geant4-v8.1.2-3193069717bb38ae4049146a49d7f9ef17715e0b/
patch -p1 < ../geant4.patch
sed -i "s|g77|gfortran|" ./config/sys/Linux-g++.gmk
cd ../
mkdir geant4.8.1.2_install
mv geant4-v8.1.2-3193069717bb38ae4049146a49d7f9ef17715e0b/ geant4.8.1.2_src
cd geant4.8.1.2_src/
mkdir data
cd data
wget http://geant4-data.web.cern.ch/geant4-data/datasets/RadiativeDecay.3.0.tar.gz
wget http://geant4-data.web.cern.ch/geant4-data/datasets/G4EMLOW.4.0.tar.gz
wget http://geant4-data.web.cern.ch/geant4-data/datasets/G4NDL.3.9.tar.gz
wget http://geant4-data.web.cern.ch/geant4-data/datasets/G4ELASTIC.1.1.tar.gz
wget http://geant4-data.web.cern.ch/geant4-data/datasets/PhotonEvaporation.2.0.tar.gz
tar -xzvf RadiativeDecay.3.0.tar.gz
tar -xzvf G4EMLOW.4.0.tar.gz
tar -xzvf G4NDL.3.9.tar.gz
tar -xzvf G4ELASTIC.1.1.tar.gz
tar -xzvf PhotonEvaporation.2.0.tar.gzcd
cd ../
./Configure -build
#Use default parameters (press Enter) for almost every thing, except:
#- Specify the path where Geant4 libraries and source files should be
#installed.
#[path/to/src] $HOME/software/geant4.8.1.2_install
#- CLHEP_BASE_DIR: $HOME/software/clhep_2.0.2.3_install
#- install shared (.so), static (.a) and global libraries without “granular”
#(you should explicitely write “n” when asked about granular libraries)
./Configure -install
cd ../geant4.8.1.2_install/src/geant4/
./Configure
source env.sh
cd
echo "# Set env. vars for Geant4" >> .bash_profile
echo "cd \$HOME/software/geant4.8.1.2_install/src/geant4/" >> .bash_profile
echo "source env.sh" >> .bash_profile
echo "cd" >> .bash_profile
Compile Packaging
cd
cd software/geant4.8.1.2_install/src/geant4/physics_lists/hadronic/Packaging
make
#if there is an error, than probably the env.sh was not sourced
echo "# Add Packaging to library path" >> .bash_profile
echo "export LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:\$HOME/software/geant4.8.1.2_install/lib/geant4/plists/Linux-g++/" >> .bash_profile
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/software/geant4.8.1.2_install/lib/geant4/plists/Linux-g++/
Install a new 64-bit version of SPICE (at the moment the version was N0067):
cd
cd software
wget https://naif.jpl.nasa.gov/pub/naif/toolkit//C/PC_Linux_GCC_64bit/packages/cspice.tar.Z
wget https://naif.jpl.nasa.gov/pub/naif/toolkit//C/PC_Linux_GCC_64bit/packages/importCSpice.csh
csh importCSpice.csh
Install planetocosmics 2.0
#Download the source files (planetocosmics_v2.0.tar.gz) and move it to the folder $HOME/software
cd
cd software
tar -xzvf planetocosmics_v2.0.tar.gz
cd planetocosmics
sed -i "s|g77 -O|gfortran -O -std=legacy -fdec -fsecond-underscore|" fortran/earth/*/GNUmakefile
sed -i "s| HepRandom| CLHEP::HepRandom|" src/PLANETOCOSApplicationScenario.cc
sed -i "s|HepRandom|CLHEP::HepRandom|" src/ROOTPartSourceGenerator.cc
sed -i "s|SV(1),SAV(25),SVV(1)|SV(25),SAV(25),SVV(25)|" fortran/earth/atmosphere/msise90_mod.f
sed -i "s|SV(1),SAV(25),SVV(1)|SV(25),SAV(25),SVV(25)|" fortran/earth/atmosphere/nrlmsise00_mod.f
#changes todo in the makefile (‘planetocosmics/makefile_root’) at lines:
#62: “CPPFLAGS += -DUSE_SPICE -I./lib/spice/include” → “CPPFLAGS += -DUSE_SPICE -I../cspice/include”
#63: “EXTRALIBS += -L./lib/spice/ -lcspice -lcsupport” → “EXTRALIBS += -L../cspice/lib -l:cspice.a -l:csupport.a”
#65: “EXTRALIBS += -lg2c” → “#EXTRALIBS += -lg2c”
#70: “” → “CPPFLAGS+=-lgfortran”
#70: (optionally) add an empty line after it
#changes to do in src/PlanetAtmosphereModel.cc at lines:
#923: ‘G4cout<<“The flux detection at this altitude will be set”<<’ → ‘G4cout<<“The flux detection at this altitude will be set”<<std::endl;’
#changes to do in src/PLANETOCOSAnalysisManager.cc:
#- insert #include"TROOT.h" after the other includes
#changes to do in src/EarthMagneticField.cc:
#insert a new line after line 340 (astream>>year;) with the code:
#if (year==0.) {break;} // the "SV" at the end should give 0
./configure root
make
source setupPLANETOCOSMICS.sh
cd
echo "# Setup planetocosmics" >> .bash_profile
echo "cd \$HOME/software/planetocosmics/" >> .bash_profile
echo "source setupPLANETOCOSMICS.sh" >> .bash_profile
cd geant4
mkdir lib
mkdir lib/Linux-g++
cp tmp/Linux-g++/PLANETOCOSMICS_ROOT/libPLANETOCOSMICS_ROOT.* lib/Linux-g++
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/geant4/lib/Linux-g++/
cd
echo "# Add planetocosmics shared library to lib path" >> .bash_profile
echo "export LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:\$HOME/geant4/lib/Linux-g++/" >> .bash_profile
Just to be precise, I used Almalinux 9.1: https://mirrors.almalinux.org/isos/x86_64/9.1.html
(Installing it in virtualbox you may choose “Version: Red Hat 9.x” for the installation, as almalinux is a Red Hat distro. Just use the iso for Almalinux, that you can download from the link.)
In this line there is an accidental ‘cd’ at the end of the line. It shoud end with .tar.gz
