Operating System: Windows 11
Compiler/Version: Visual Studio 18 2026
Hi
Is there a full guide, step-by-step, to install a Geant4 application and all the dependencies on Windows, supporting:
multithreading
QT visualization
HDF5
GDML
ROOT
Thanks a lot in advance
Michael
bmorgan
November 21, 2025, 11:21am
2
Installing Geant4 itself is covered in the Installation Guide . Building an application is covered in both the Installation Guide: How to Use and the Application Developer Guide .
Installation of Qt, Xerces-C, HDF5 and ROOT will be covered on their respective sites.
Thanks @bmorgan
last question: which are the flags I need to enable during HDF5 build from cmake in order to support also multithreading?
Thanks
bmorgan
November 21, 2025, 2:07pm
4
Check the HDF5 install guide here:
* Build and Install HDF5 C, C++, Fortran and High-Level Libraries *
* and tools with CMake *
Table of Contents
Section I: Preconditions
Section II: Quick Step Building HDF5 Libraries with CMake Script Mode
Section III: Quick Step Building HDF5 Libraries with CMake Command Mode
Section IV: Further Considerations
Section V: Options for building HDF5 Libraries with CMake Command Line
Section VI: CMake option defaults for HDF5
Section VII: User Defined Options for HDF5 Libraries with CMake
Section VIII: User Defined Compile Flags for HDF5 Libraries with CMake
Section IX: Considerations for Cross-Compiling
Section X: Using CMakePresets.json for Compiling
Section XI: Using the Library
Section XII: Using CMake Regex Options for Testing
Section XIII: Java FFM Testing
This file has been truncated. show original
or the relevant one for the version you’re installing. It should be HDF5_ENABLE_THREADSAFE pretty consistently though. Bear in mind HDF5 support is still considered experimental in Geant4, especially on Windows.
Thanks,
And last do you suggest also the installation of VecGeom?
Honestly I don’t get the difference between installing and not
Thanks
