geant4-v11.2.1
Ubuntu 22.04
GCC 11.4.0
cmake version 3.29.0
Having error with cmake not being able to identify some files
CMake Error at B1/CMakeLists.txt:15 (find_package):
By not providing "FindGeant4.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Geant4", but
CMake did not find one.
Could not find a package configuration file provided by "Geant4" with any
of the following names:
Geant4Config.cmake
geant4-config.cmake
Add the installation prefix of "Geant4" to CMAKE_PREFIX_PATH or set
"Geant4_DIR" to a directory containing one of the above files. If "Geant4"
provides a separate development package or SDK, be sure it has been
installed.
Hi Lakshya:
As is shown in this error report, you need to specify the location of Geant4Config.cmake file whenever you use cmake to compile any Geant4 file.
The default location of Geant4Config.cmake is
${your Geant4 installation path}/lib/cmake/Geant4
If you can find Geant4Config.cmake in this path, add
-DGeant4_DIR=${your Geant4 installation path}/lib/cmake/Geant4
when using cmake.
For example, if you want to compile B1 example in B1/build path, you should use
cmake -DGeant4_DIR=${your Geant4 installation path}/lib/cmake/Geant4 ..
I also suggest add the following line to your .bashrc so that you can use g4cmake to compile Geant4 project instead of typing the long cmake command mentioned above.
alias g4cmake='cmake -DGeant4_DIR=${your Geant4 installation path}/lib/cmake/Geant4'
You can also find this solution to your problem in the official Geant4 installation guide: How to Use the Geant4 Toolkit Libraries — Geant4 Installation Guide 11.2 documentation
geant4 has configuration file.
Before tried cmake configuration which any example or you own geant4 application you need
sources ${your Geant4 installation path}/bin/geant4.sh
or geant4.csh depending on shell you are using.
This must be done ones when you open new terminal or tab.
Hi, Thanks you for the reply I followed your steps and I was able to run my program…
Thank you for the reply I’ll make sure I do that
