Issue compiling Geant 4 V11.3.1 on MacOS 15.4
_Geant4 Version:_V11.3.1
_Operating System:_MacOS 15.4
Compiler/Version: clang, as decided by ccmake automated software
_CMake Version:_4.0.0
I am running an Apple M3 laptop computer
I dowloaded the last version of Geant 4, V11.3.1
Uncompress the .z file.
then in the repertorr-y geant4-v11.3.1-Build, I run:
ccmake ../geant4-v11.3.1
minor adjustement are needed in order to find the Qt@5 confioguration softwares.
Then I can generate the Makefile. Then
make
It works for a while. The I get many time the warning:
In file included from /Users/yvon/AliBaba/Librairies_CERN/geant4-v11.3.1/source/externals/zlib/src/adler32.c:8:
/Users/yvon/AliBaba/Librairies_CERN/geant4-v11.3.1/source/externals/zlib/include/zutil.h:170:11: warning: ‘OS_CODE’ macro redefined [-Wmacro-redefined]
  • 170 | # define OS_CODE 19*
/Users/yvon/AliBaba/Librairies_CERN/geant4-v11.3.1/source/externals/zlib/include/zutil.h:141:11: note: previous definition is here
  • 141 | # define OS_CODE 7*
1 warning generated.
Then It breaks:
In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/stdio.h:61:
/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/_stdio.h:318:7: error: expected identifier or ‘(’
  • 318 | FILE *fdopen(int, const char ) __DARWIN_ALIAS_STARTING(__MAC_10_6, __IPHONE_2_0, __DARWIN_ALIAS(fdopen));
/Users/yvon/AliBaba/Librairies_CERN/geant4-v11.3.1/source/externals/zlib/include/zutil.h:147:33: note: expanded from macro ‘fdopen’
  • 147 | # define fdopen(fd,mode) NULL /* No fdopen() /
/Library/Developer/CommandLineTools/usr/lib/clang/17/include/__stddef_null.h:26:16: note: expanded from macro ‘NULL’
  • 26 | #define NULL ((void*)0)*
Can you help?
Best regards
Dominique Yvon
Try setting -DGEANT4_USE_SYSTEM_ZLIB=ON.
Geant4 v11.3.1 has not been tested on macOS 15.4 and clang-17.
I does work much better !
Thanks
thanks same issue it worked
