Issue running laserDrivenBeamline.mac in hadrontherapy example
Hi all!
I’m a relative newbie to GEANT4 and have an issue regarding running macros in the command line. In particular, I would like to run laserDrivenBeamline.mac in the hadrontherapy example.
When I run
./hadrontherapy ../macro/laserDrivenBeamline.mac
in the build directory, I get the following error:
***** COMMAND NOT FOUND </process/had/rdm/thresholdForVeryLongDecayTime 1.0e+60 year> *****
*** G4Exception : UIMAN0123
Command aborted (100)
Error code : 100
When I run the executable (./hadrontherapy), I do not receive an error. However, when I run
/control/execute laserDrivenBeamline.mac
in the visualization, I receive the following error:
***** Illegal application state </geometrySetup/selectGeometry LaserDriven> *****
Command aborted (200)
Error code : 200
illegal application state – command refused:“/control/execute laserDrivenBeamline.mac”
In a previous thread, the latter error was attributed to GEANT4’s inability to change geometry once an already loaded geometry. However, I receive the former error when I try the thread’s recommended solution (implementing the macro in the command line).
How should I best go about running the macro? Is there another way I should do so?
Completely aside, there’s a typo in the visualization manager. In the “Documentation :” section, it links the “Visualisation Publication :” with “visualization” spelled as so.
Hi Samuel
I’m not familiar with the hadrontherapy example, but it’s usual to run your application in a working directory containing the macro files. So rather than a full pathname to the macros
cd to the macro directory, then give the full pathname of the executable:
<path_to_executable_directory>/hadrontherapy laserDrivenBeamline.mac
Let us know if this helps.
Hi John
Thank you for your response.
I ran the executable in the macro directory, but am still encountering the following error:
I also reinstalled G4; however, the error persists.
I would greatly appreciate any suggestions you might have to resolve this issue.
Thank you for your time and assistance.
Samuel
Hi Samuel
Maybe the command is simply not there. Have you looked at the help tree? (help, or ls, cd, etc.). In an app I am developing it is not there, but maybe I don’t have the right physics list. If it’s not there in the hadrontherapy example, it’s a bug. If you don’t get a response from a hadron expert, please file a bug report.
