_Geant4 Version:_10.00.p02
_Operating System:_CentOS-7
_Compiler/Version:_gcc 12.1.0
I am trying to install Geant4-v10.00.p02, but am getting an the following error when running exampleB1:
*** G4Exception : PART70000
issued by : G4NuclideTable
G4ENSDFSTATEDATA environment variable must be set
I believe that this is related to the downloading of the associated data files when building the project.
By default, cmake is configured to download the data files from “http://geant4.cern.ch/support/source”; however, this URL no longer seems to exist. I was able to find the new URL for the data files (“https://cern.ch/geant4-data/datasets”), so I instead pointed cmake to download the files from this source. When building the project, these files are successfully downloaded and copied to my install directory, except for G4ENSDFSTATE1.0/.
I have tried manually copying over this directory and setting the correct environmental variable, but this leads to a separate error that seems to be related to an incorrect formatting of one of the data files. This leads me to believe that my approach causes an incorrect version of the data files to be downloaded, leading to the exception when running the example.
Can someone provide me with the proper way to retrieve these data files given their new location? Thanks in advance for any suggestions.
