_Geant4 Version:_11.3.1 (21-March-2025)
_Operating System:_Windows 11 Enterprise
_Compiler/Version:_Microsoft Visual Studio Community 2022 (2) (64-bit) - Version 17.12.1
_CMake Version:_3.31.6
I am trying to run “geant4\examples\extended\runAndEvent\RE03”, but got two issues in “RE03UserScoreWriter.cc”:
- For this line " ofile << voxelIndex << " " << doseValue << G4endl;", VS complained “no operator “<<” matches these operands”.
how to fix:
ofile << voxelIndex << " " << doseValue.GetSumW() << G4endl;
- For this line, “std::map<G4int, G4double*>::iterator value = score->find(idx);” VS complained “identifier “score” is undefined”.
how to fix:
auto value = scoreMap->find(idx);
if (value != scoreMap->end()) {
projxy[y] += value->second->sum_w();
Looks like this example has not been run for a long time. Though ChatGPT was able to find the solutions quickly, at the same time, I think the sample code should be updated.
Could you confirm this is the example from Geant4 11.3.1, and that you have not made modifications to it please? I can’t find a line matching the first one, and in the second case, there is an identifier score:
then used here:
Our nightly tests are building and running this example, with Windows and VS as follows:
-- Selecting Windows SDK version 10.0.22621.0 to target Windows 10.0.26100.
-- The C compiler identification is MSVC 19.40.33808.0
-- The CXX compiler identification is MSVC 19.40.33808.0
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe - skipped
-- Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe - skipped
Could you post the output you are getting from CMake please?
