I could compile Geant4.11.1 on a Mac M2 without problem. The make install
showed the following progress:
[ 0%] Built target ptl-shared
[ 2%] Built target G4clhep
[ 4%] Built target G4global
[ 5%] Built target G4intercoms
[ 5%] Built target G4zlib
[ 98%] Built target G4GMocren
[ 98%] Automatic MOC for target G4ToolsSG
[ 98%] Built target G4ToolsSG_autogen
[ 98%] Automatic MOC for target G4OpenGL
[ 98%] Built target G4OpenGL_autogen
[100%] Built target G4OpenGL
[100%] Built target G4visQt3D
G4ToolsSG
was compiled automatically. I expect G4gl2ps
to appear between G4Global
and G4intercoms
. But it didn’t.
I could use this build to compile some Geant4 applications. But when I tried to run it, I got
dyld[42437]: Library not loaded: @rpath/libG4gl2ps.dylib
Referenced from: <DC126C27-0E34-3044-B6A3-C09F3A8C777D> /Users/jing.liu/geant4/gears/gears
Reason: tried: '/Users/jing.liu/geant4/11.1.0/lib/libG4gl2ps.dylib' (no such file), '/libG4gl2ps.dylib' (no such file), '/usr/local/lib/libG4gl2ps.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/lib/libG4gl2ps.dylib' (no such file), '/usr/local/lib/libG4gl2ps.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/lib/libG4gl2ps.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS@rpath/libG4gl2ps.dylib' (no such file), '/usr/local/lib/libG4gl2ps.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/lib/libG4gl2ps.dylib' (no such file), '/usr/local/lib/libG4gl2ps.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/lib/libG4gl2ps.dylib' (no such file), '/usr/local/lib/libG4gl2ps.dylib' (no such file), '/usr/lib/libG4gl2ps.dylib' (no such file, not in dyld cache)
zsh: abort gears
Do I have to set some CMake flags to enable the compilation of libG4gl2ps?
Thanks,
Jing
PS, CMakeCache.txt is attached.
CMakeCache.txt (52.0 KB)
