Dear all,
I would like to manually step through my geometry to get a hand on the material properties for studies and tracking etc.
My idea is to use the G4Navigator with the LocateGlobalPointAndSetup and ComputeStep method to step though the single materials. Starting from a given point the ComputeStep method is called to obtain the stepLength towards the next boundary in the respective direction, then with a tiny push one can cross the boundary and is in the next volume,
This method works nicely with all my geometry (CAD - tessellated, reflections, etc.) but unfortunately not with a volume containing a G4PVReplica → segmentation violation in LocateGlobalPointAndSetup.
Also in works with no problems using the normal G4 simulation. Therefore I assume that the geometry is fine and I am just missing something in my LocateGlobalPointAndSetup method
Example for Geometry creation with G4PVReplica:
// 1. Mother volume - sensor
G4Box* sensor = new G4Box( "Sensor", (pixelSizeX * numberPixelX) / 2.0, (pixelSizeY * numberPixelY) / 2.0,pixelTickness / 2.0 );
G4LogicalVolume* sensorLV = new G4LogicalVolume(sensor, helium, sensor->GetName());
// 2. Replica volume - row
G4Box* row = new G4Box( "row", (pixelSizeX * numberPixelX) / 2.0, pixelSizeY / 2.0, pixelThickness / 2.0);
G4LogicalVolume* rowLV = new G4LogicalVolume(rowSolid,helium,rowSolid->GetName());
// 3. Create replica row volume in mother sensor
new G4PVReplica(rowLV->GetName(), rowLV, sensorLV, kYAxis, numberPixelY, pixelSizeY);
Example for manual stepping using LocateGlobalPointAndSetup and ComputeStep:
G4Navigator* g4Navigator = new G4Navigator();
g4Navigator->SetWorldVolume( worldConstruction->getWorldVolume() );
const G4ThreeVector direction(0,0,1); // Simply go along z-axis
const double proposedPhysicsStep = 10 * CLHEP::m;
while( currentZ < endZ ) {
G4ThreeVector point( 0 * CLHEP::mm, 0 * CLHEP::mm, currentZ);
G4VPhysicalVolume *volume = g4Navigator->LocateGlobalPointAndSetup( point, nullptr, true, true );
const double radLen = volume->GetLogicalVolume()->GetMaterial()->GetRadlen();
const double density = volume->GetLogicalVolume()->GetMaterial()->GetDensity();
double newSafety;
double stepLength = g4Navigator->ComputeStep( point, direction.unit(), proposedPhysicsStep, newSafety );
if( stepLength > proposedPhysicsStep ) {
stepLength = proposedPhysicsStep;
stepLength += 0.1 * CLHEP::um; // Cross boundary - flexible
currentZ += stepLength; // Proceed along z
Maybe there is also a smarter way to do this - but fromt the principle point of view it works - as long as one does not use G4PVReplica volumes.
G4 Version: 10.5.0
Thank you very much for any feedback on this.
